hallo
ik heb om te proberen 5 ATtiny13 gekocht om te proberen.
nu heb ik gewoon blink met 3 ledjes die werkt prima op ATtiny85.
maar met ATtiny13 totaal verschil, ik heb al millis gebruikt,want delay kon problemen geven.
maar welke instelling ik ook probeer van ATtiny13 het werkt niet
ik heb deze ATTiny13 core die op deze site besproken word voor arduino 1.6.4
http://forum.arduino.cc/index.php?topic=89781.msg2234412#msg2234412
en dit is de code die ik nu heb ,wat moet ik daar aan aanpassen om het goed werkend te krijgen???
/* Blink without Delay
Turns on and off a light emitting diode(LED) connected to a digital
pin, without using the delay() function. This means that other code
can run at the same time without being interrupted by the LED code.The circuit:
- LED attached from pin 13 to ground.
- Note: on most Arduinos, there is already an LED on the board
that's attached to pin 13, so no hardware is needed for this example.created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul StoffregenThis example code is in the public domain.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
*/// constants won't change. Used here to
// set pin numbers:
const int ledPin = 0;
const int ledPin1 = 1;
const int ledPin2 = 2;// Variables will change:
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000; // interval at which to blink (milliseconds)void setup() {
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
pinMode (ledPin1,OUTPUT);
pinMode(ledPin2,OUTPUT);
}void loop()
// here is where you'd put code that needs to be running all the time.// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
unsigned long currentMillis = millis();if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
digitalWrite(ledPin1, ledState);
digitalWrite(ledPin2, ledState);
