ATtiny13A programming issue ( Invalid device signature 0x000000)
Some months ago i've bought a USBASP v2.0 and i've unsuccessfully tried to flash a atmega 8A that i've replaced in a ESC (with the same error of now). :angry:
Some week ago i've received 4 ATtiny 13a and yesterday i've tried to upload the BLINK sketch with ARDUINO UNO (as ISP )and with the USBASP, but all the attempts the sketch/bootloader upload fail for the same reason. >:( >:(
I've tried the following things:
1)attiny13 core (Core13 download | SourceForge.net)
2)this guide http://www.instructables.com/id/Programming-an-ATTiny13A-using-Arduino-servo-int/
3)change attiny, cable, breadboard
4)connect the cables directly to the ATtiny13
  1. reinstall arduino
5)follow all the guide and the suggestions found on the forum
What can be the problem? the PC ?
Error:
Device signature = 0x000000
Yikes! Invalid device signature.
Double check connections and try again, or use -F to override this check.
ARDUINO UNO as ISP verbose output
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM6
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATtiny13
         Chip Erase delay              : 4000 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no         64    4      0  4000  4000 0xff 0xff
           flash         65     6    32    0 yes      1024   32     32  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [14] . [00] . [00] . [01] . [01] . [01] . [01] . [02] . [ff] . [ff] . [ff] . [ff] . [00]   [20] . [00] @ [40] . [00] . [00] . [04] . [00]   [20]
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny13
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.06s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
USBasp V2.0 verbose output
         Using Port                    : usb
         Using Programmer              : usbasp
avrdude: seen device from vendor ->www.fischl.de<-
avrdude: seen product ->USBasp<-
         AVR Part                      : ATtiny13
         PAGEL                         : P00
         BS2                           : P00
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         this check.
I had a similar problem some months ago and asked on here, please look at this topic...
see Hiduino's response
hi, thanks for the answer
I had already seen your post, but the "-B4" don't work, the only difference is the SCK (for the -B4 period set)
avrdude: try to set SCK period to 4e-006 s (= 250000 Hz)
avrdude: set SCK frequency to 187500 Hz
this check.
help :cry:
I was about to ask the same question.
One remarkable thing is, arduino uno is programmed as isp with oscillator off (see avrdude output). Does it mean the internal oscillator is used? My board has a quartz 12MHz, is it not used?
If not, I think, this is the problem. The clock-rate is too slow for holding 19200 baud stable, so avrdude breaks the connection after some errors. Actually, sometimes (one attempt of ten) I was able to run an avrdude -v command and got the response, that the board was available and ready.
In some forums there were a hint, that a stable external power source would help. It didn't help in my case.
So, is it possible to program arduino as isp and use the oscillator on board? What would be the value of fuse-bytes?
I'm using the same library (looks like:
Arduino core designed for Attiny13 and similar devices.
NO WARRANTEE OR GUARANTEES!
Written by John "smeezekitty"
Version 0.19)
I have not upgraded my USBASP, even though I get the warning at every upload - be it t85, Mini Pro or Nano3.
I am wiring the USBASP to tinyXX using duponts on a breadboard.
And I have no problems at all.
After t13A, I have programmed t85 in the same very specific setup :wink:
Also, I use eXtreme burner, for checks, or binary uploads - I have copied the HEX from t13A, then write to t85 with no issues using this setup.
  1. Please post some pics or schematics to your wiring and
  2. double check your core 13 installation.
hi, i've checked the wiring a lot of times, this night i will upload some pics of my wiring, thanks for the help.
Still having problems ??
I would still recommend this...
Go to the arduino-1.0.4\hardware\tools\avr\etc\avrdude.conf and edit the line around line number 319 to:
# default_bitclock = 2.5
default_bitclock = 10
I had similar problems and this change FIXED IT IMEDIATELY
.. not forgetting to reboot your IDE after the edit
