Hi!
I was trying to burn bootloader to Attiny13A-PU using Arduino as ISP (Leonardo) and the MicroCore core.
I tried using the normal SPI header, the pins 11, 12, 13 and multiple programmer names (e.g. ArduinoISP, Arduino as ISP, and their slow versions) and I scored nothing.
The error message is here:
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\szyme\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\1.0.0/avrdude.conf"
Using Port : COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
Setting bit clk period : 32.0
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Błąd przy wgrywaniu bootloadera.
avrdude done. Thank you.
Can anyone help me?
