I am using an Attiny13A and I can not get the timer overflow interrupt to work properly.
This is a small version of the full version of the code (quite large) but reproduces the problem.
#define F_CPU 128000
#include <avr/io.h>
#include <util/delay.h>
volatile unsigned long x=0;
SIGNAL(TIMER0_OVF_vect){x=1;} //Set x to 1
int main(){
TCCR0B |= _BV(CS01); //Prescaler to F_CPU/8
TCCR0A |= _BV(WGM00)| _BV(WGM01);
TIMSK0 = _BV(TOIE0); //Enable timer overflow interrupt
DDRB = 0x18; //PB3 and PB4
asm("sei"); //Enable interrupts
while(1){
PORTB ^= 0x8; //Invert vale on PB3
if(x){PORTB |= 0x10;} //Turn on PB4 after the interrupt
_delay_ms(500); //Blink delay
Expected behavior is that PB3 would blink and PB4 would light. Actual behavior is PB3 would flicker at about 20 times per second and PB4 does not light.
But if I change it to:
#include <avr/io.h>
int main(){
while(1){
asm("sei"); //Enable interrupts *moved*
Again I expect the same behavior as before but now PB3 actually blinks at the correct rate but PB4 still does not light.
I have been Googling for hours and can not find a solution.
It seems to match the examples as well.
