Sorry, I did tell the wrong pin. I am using PB0.
Here is the complete code:
// Charlieplexing 12 LEDs with an Attiny13
// A N Peck May 2020
const int buttonPin = PB0; // the number of the pushbutton pin
const byte looper = 5; // how many times for each effect?
const byte betweenies = 1000; // delay time between effects
uint16_t myrand = 2901; // initial value for random seed
int buttoncount = 0; // variable for reading the pushbutton status
// the LEDs port direction and portstate 12 x 2 array
const byte leds12 [12][2] =
{0b00000110, 0b00000010}, // LED a
{0b00000110, 0b00000100}, // LED b
{0b00001100, 0b00000100}, // LED c
{0b00001100, 0b00001000}, // LED d
{0b00011000, 0b00001000}, // LED e
{0b00011000, 0b00010000}, // LED f
{0b00001010, 0b00000010}, // LED g
{0b00001010, 0b00001000}, // LED h
{0b00010100, 0b00000100}, // LED i
{0b00010100, 0b00010000}, // LED j
{0b00010010, 0b00000010}, // LED k
{0b00010010, 0b00010000}, // LED l
// take the port direction, port state and delay to make the LEDs light up
void lightemup (byte portdirection, byte portstate, int mydelay) {
DDRB = portdirection;
PORTB = portstate;
delay(mydelay);
// a little bit of zero led activity if needed
void deadled (int howlongdead) {
lightemup(0b00000000, 0b00000000, howlongdead);
pinMode(buttonPin, INPUT);
attachInterrupt(buttonPin, Button, CHANGE); // Hier findet die Einbindung unseres Interrupt-Befehls statt
// a memory blowout in the next two lines to initialise random number
pinMode(PB1, INPUT);
myrand = analogRead(PB1);
// linear feedback shift register "randomiser"
uint16_t gimmerand(uint16_t small, uint16_t big) {
myrand ^= (myrand << 13);
myrand ^= (myrand >> 9);
myrand ^= (myrand << 7);
return abs(myrand) % 23 * (big - small) / 23 + small;
// random light effect
void randomleds() {
for (byte theloops = 0; theloops < 100; theloops++) {
byte thislight = gimmerand(0, 12);
lightemup(leds12[thislight][0], leds12[thislight][1], 50);
deadled(50);
// moving single led backwards and forwards
void cylons() {
for (byte theloops = 0; theloops < looper; theloops++) {
for (byte outercount = 0; outercount < 12; outercount++) {
lightemup(leds12[outercount][0], leds12[outercount][1], 200);
deadled(25);
for (byte outercount = 10; outercount > 0; outercount--) {
deadled(25);
lightemup(leds12[0][0], leds12[0][1], 200);
deadled(25);
// moving two leds backwards and forwards together
void twobytwo() {
for (byte outercount = 0; outercount < 10; outercount++) {
for (byte innercount = 0; innercount < 40; innercount++) {
lightemup(leds12[outercount][0], leds12[outercount][1], 1);
lightemup(leds12[outercount + 2][0], leds12[outercount + 2][1], 1);
for (byte outercount = 8; outercount > 1; outercount--) {
lightemup(leds12[0][0], leds12[0][1], 1);
lightemup(leds12[2][0], leds12[2][1], 1);
deadled(1);
// two leds moving from side to side
void backandforthone() {
for (byte outercount = 0; outercount < 6; outercount++) {
for (byte innercount = 0; innercount < 110; innercount++) {
lightemup(leds12[11 - outercount][0], leds12[11 - outercount][1], 1);
deadled(1);
// four leds moving from side to side
void backandforthtwo() {
for (byte outercount = 0; outercount < 11; outercount++) {
for (byte innercount = 0; innercount < 20; innercount++) {
lightemup(leds12[outercount + 1][0], leds12[outercount + 1][1], 1);
lightemup(leds12[10 - outercount][0], leds12[10 - outercount][1], 1);
deadled(1);
// choose effect
Button();
// randomleds();
// delay(betweenies);
// cylons();
if (buttoncount = 0)
{ twobytwo();
if (buttoncount = 1) {
backandforthone();
// backandforthtwo();
void Button() {
// static unsigned long last_interrupt_time = 0;
// unsigned long interrupt_time = millis();
buttoncount = digitalRead(buttonPin);
if (buttoncount < 1) {
buttoncount++;
else {
buttoncount = 0;
