Attiny13A without PWM
Attiny13A uses MicroCore 2.3.0. I download the code through the programmer. My PWM does not work, it is not on any contact (I am a beginner), what could be the problem? Here is the code:
#define npn 1
#define btn_1 2
#define btn_2 3
byte value = 0;
void setup(){
  pinMode(npn, OUTPUT);
  pinMode(btn_1, INPUT);
  pinMode(btn_2, INPUT);
void loop(){
  if(digitalRead(btn_1) == 1){
    if(value < 255){
      value++;
      analogWrite(npn, value);
  if(digitalRead(btn_2) == 1){
    if(value != 0){
      value--;
  delay(50);
Please explain what you expected to happen, what happened instead, and what you have done to debug the problem.
Also post a pic of a hand drawn wiring diagram, with pins, parts and connections clearly labeled.
