Attiny24 Timer0 setting up
I'm trying to call a timer interrupt with Attiny 24. I've gone through the documentation, done the work; the code is:
  cli();
  //TCCR0A - set 0b0000RR10 - pins disconnected, CTC mode, reset at OCRA
  TCCR0A = 0;
  TCCR0A |= (1<<WGM01);
  //TCCR0B set to 0b00RR0101 - prescaler 1024,
  TCCR0B = 0;
  TCCR0B |= (1<<CS02);
  TCCR0B |= (1<<CS00);
  //initial value in counter 0, count up to 244
  TCNT0 = 0;
  OCR0A = 244;
  //enable interrupt on A
  TIMSK0 = 0;
  TIMSK0 |= (1<<OCIE0A);
  sei();
The idea is: prescaler 1024 at 1MHz clock counts up approximately 1000 times per second; I count up to about 250 -> about 4 interrupts per second. The IRQ handler is just toggling an LED:
ISR(TIM0_COMPA) {
  time_elapsed++;
  digitalWrite(output, digitalRead(output) ^ 1);    //toggle pin ON/OFF
The LED lights up once and then stays on. What am I doing wrong with the setup? Is there a register I forgot? Should I use Timer1 instead, or something like that?
Thank you!
I suggest you post your complete code, so people can test it.
thanks for the prompt. A full code that doesn't work is below; all setup I have is an LED on pin 10. In the setup, its blinks once and then stays on even though the interrupts should turn it off. Once I have this I can start changing the ISR to actually do something meaningful but as of now, I don't really know if the interrupt is triggered or not.
int output = 10;
ISR(TIMER0_COMPA_vect) {
  //test connection - LED at pin 10 should blink once ON-OFF
  pinMode(output,OUTPUT);
  digitalWrite(output,HIGH);
  //setup the timer 1
  cli();
  TCCR0A = 0;
  TCCR0B = 0;
  TCNT0 = 0;
  OCR0A = 244;
  TIMSK0 = 0;
  sei();
Was something missing in the top section of the code?
It looks like you have one closing bracket too many
i removed the one just above
I have no AT24 to test (only AT85).
Just a shot: what happens if you change:
int output = 10;
to
volatile int output = 10;
I've modified the ISR without testing it, hence the missing bracket; before I had a simple if-else counter there.
The volatile doesn't seem to work; it just turns the LED on once and then doesn't do the toggling, hence why I think it doesn't call the interrupt correctly repeatedly but only once.
Maybe the settings it wrong and it has too long/too short period? Is it possible that after it's called once some flags are reset that disable further calls?
I've overcome the issue; instead of using a timer, I resorted back to millis() function, with rollover handling per https://www.baldengineer.com/arduino-how-do-you-reset-millis.html
I still don't understand why the timer doesn't work but my problem with determining the timings of things in the system was thus resolved. In case anyone else encounters a similar issue, feel free to use this alternative.
