Hello,
I would like to make an Attiny44 sleep in power down for 10 seconds and wake for 2 seconds using the wdt. Please can some advise me on some code for this.
Any help would be greatly appreciated.
Thanks,
J
Hello,
Thanks,
J
If codes are provided, then how are you going to test them? What kind of hardware setup you have?
#include <avr/sleep.h>
#include <avr/wdt.h>
#define adc_disable() (ADCSRA &= ~(1 << ADEN)) // Disable ADC to save a lot of current consumption.
int ledState = 0; // Allows easy tracking of whether LED is on or off.
int ledPin = 4;
// Use these values to set the on and off time period. The sketch uses 6 for 1 second on, 1 second off..
// 0 = 16ms, 1 = 32ms, 2 = 64ms, 3 = 128ms, 4 = 250ms, 5 = 500ms, 6 = 1 sec, 7 = 2 sec, 8 = 4 sec, 9 = 8 sec
int period = 9; // This = 4 second timeout. Refer to table above
volatile boolean f_wdt = true;
adc_disable(); // ADC uses ~320uA.
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // This is the lowest power consumption mode.
pinMode(ledPin, OUTPUT);
setup_watchdog(period); // Set watchdog to wake system each 8 seconds.
} // End of setup()
if (f_wdt == 1) // If this flag is set then watchdog timed out. This happens each second.
f_wdt = false; // Reset the 'watchdog has timed out' flag.
if (ledState == 0)
ledState = 1;
digitalWrite(ledPin, HIGH);
ledState = 0;
digitalWrite(ledPin, LOW);
systemSleep();
} // End of loop()
// Put system to sleep. It will be woken when the watchdog times out.
void systemSleep()
sleep_enable();
sleep_cpu();
sleep_disable(); // System continues execution here when watchdog times out.
} // End of systemSleep()
// This ugly code manipulates some internal registers of the ATtiny.
void setup_watchdog(int interval)
byte bb;
if (interval > 9 ) interval = 9;
bb = interval & 7;
if (interval > 7) bb |= (1 << 5);
bb|= (1 << WDCE);
MCUCR &= ~(1 << WDRF);
WDTCSR |= (1 << WDCE) | (1 << WDE);
WDTCSR = bb; // Set new watchdog timeout value.
WDTCSR |= _BV(WDIE);
} // End of setup_watchdog()
// This is the watchdog Interrupt Service Routine (ISR). It is executed when the watchdog times out but does nothing. The real work is done in loop().
ISR(WDT_vect)
f_wdt=1;
} // End of ISR()
Hi There,
I have just added my code above.
I am using an attiny44.
Thank you for this
, I thought there may be a way around it. I would still like to wake and sleep at different intervals to reduce power as much as possible.
I am using an USBASP-Programmer.
Have you tried the sketch of your post #3? Is it working?
Can you post pictures of your Programmer and the ATtiny Chip?
