Hi. I have a sketch that I downloaded to an ATtiny45 to trigger a sequence of 5 LEDs, but for some reason, the output of pin 2 (assigned to LED #3) from the tiny is dim. In fact, it's only 2.5V, and it should be 5V. However, when I assign pin 3 to LEDs #3 and #4, the result is perfect, and bright. Can someone explain why this happens? Thanks so much! Here is the sketch:
int Led1 = 0;
int Led2 = 1;
int Led3 = 2;
int Led4 = 3;
int Led5 = 4;
void setup(){
pinMode (Led1, 5);
pinMode (Led5, 6);
pinMode (Led2, 7);
pinMode (Led3, 3);
pinMode (Led4, 3);
void loop(){
digitalWrite (Led1, HIGH);
delay (75);
digitalWrite (Led1, LOW);
delay (75);
delay (75);
delay (75);
delay (200);
digitalWrite (Led2, HIGH);
delay (75);
digitalWrite (Led2, LOW);
delay (75);
delay (75);
delay (75);
delay (200);
digitalWrite (Led3, HIGH);
delay (75);
digitalWrite (Led3, LOW);
delay (75);
delay (75);
delay (75);
delay (200);
digitalWrite (Led4, HIGH);
delay (75);
digitalWrite (Led4, LOW);
delay (75);
delay (75);
delay (75);
delay (200);
digitalWrite (Led5, HIGH);
delay (75);
digitalWrite (Led5, LOW);
delay (75);
delay (75);
delay (75);
delay (200);
