Hi guys,
Would anyone happen to know the minimum common mode voltage that can be sent to the ATTiny differential ADC? I need to measure the voltage across a current sense resistor, and so I would like to attach the inverting side of the built-in op-amp to ground - which is the low side of the sense resistor - and the non-inverting side to the high side of the resistor. With op-amps, the minimum voltage is specified as the minimum common mode input voltage, but there seems to be no such thing in the Atmel datasheet.
Thanks!
