attiny84 baudrate problem
hi forum,
i´m using the arduino as an isp to program my attiny84 20pu for midi purposes.
now during the first midi program i've run into an error:
the MIDI baudrate is set at 31.25 k
but the supporting libs only allow me to program the in 9**,6k, 38,4k** and 115,2k baudrate.
my question is how to set the serial baudrate of the attiny to 31,25k
note: i have been succefull in programming the attiny and this question is purely code based
i've used this tutorial for programming the attiny : http://www.instructables.com/id/Program-an-ATtiny-with-Arduino/
daatse:
Are you sure? Last time I looked they supported any baud rate.
not entirly, but when im trying to compile my code with the
Serial.begin(31250);
i get this error:
In member function 'void TinyDebugSerial::begin(long int)',
    inlined from 'void setup()' at basis.ino:44:
C:\Program Files (x86)\Arduino\hardware\tiny\cores\tiny/TinyDebugSerial.h:694: error: call to 'TinyDebugSerialBadBaud' declared with attribute error: Serial (TinyDebugSerial) supports three baud rates: 9600, 38400, or 115200
daatse:
i get this error:
Ok, I didn't know "supporting libs" meant "TinyDebugSerial".
Looks like you're going to have to go in and hack the source code for TinyDebugSerial to support another baud rate.
http://forum.arduino.cc/index.php/topic,85181.0.html
http://itp.nyu.edu/physcomp/Labs/MIDIOutput
I'm now trying to use the softwareserial library which as i found out with the link above. it still doesn't work but at least the baud-rate is accepted and the proper pins can be set...
one drawback is the amount of space the library uses on the attiny's flash, but there can be ways around that
to be continued
TinyDebugSerial is send only (no receive). Will that be a problem for your application?
If you want two way comms with custom baud rate and a similar interface as the standard Serial command, you can extract the TinySoftwareSerial from here:
There are some downsides:
(1) it is half duplex - you cannot send and receive at the same time, but then all software serial codes are.
(2) there are fixed pins: TX=PA1, RX=PA2
(3) its integrated into the ATTinyCore, so if you want to use it in another core then a tiny bit of mod will be required (just add a couple of lines to the header file).
(4) as with all serial, if you are using the internal oscillator you will need to tune it to get accurate baud rates.
Unless properly written.
thank you very much for your help im going to give that lib a spin,
thats fine because i don't need to be able to do that anyway
isn't this changable ?
i am using the internal osc, of 8mhz, so how would i tune this the right way
The pins aren't changeable, no. It uses the analog comparator as an interrupt source so as not to waste the INT0 source.
You can use 'TinyTuner' to tune the oscillator.
(http://forum.arduino.cc/index.php/topic,8553.0.html)
You will need to add these lines to the very top of the TinySoftwareSerial.h file if you are not using it as part of the core.
  Where to put the software serial? (AVR Pin Bits and Registers)
//WARNING, if using software, TX is on AIN0, RX is on AIN1. Comparator is favoured to use its interrupt for the RX pin.
#define USE_SOFTWARE_SERIAL                                                  1
//Please define the port on which the analog comparator is found.
#define ANALOG_COMP_DDR                                                           DDRA
#define ANALOG_COMP_PORT                                                  PORTA
#define ANALOG_COMP_PIN                                                           PINA
#define ANALOG_COMP_AIN0_BIT                                          1
#define ANALOG_COMP_AIN1_BIT                                          2
