Attiny84 blink in Assenbly
The following program runs on an Arduino:
; written by: 1o_o7
; date: <2014|10|29>
; version: 1.0
; file saved as: blink.asm
; for AVR: atmega328p
; clock frequency: 16MHz (optional)
; Program funcion:---------------------
; counts off seconds by blinking an LED
; PD4 ---> LED ---> R(330 ohm) ---> GND
.nolist
.include "./m328Pdef.inc"
.list
; Declarations:
.def temp = r16
.def overflows = r17
.org 0x0000              ; memory (PC) location of reset handler
rjmp Reset               ; jmp costs 2 cpu cycles and rjmp costs only 1
                         ; so unless you need to jump more than 8k bytes
                         ; you only need rjmp. Some microcontrollers therefore only
                         ; have rjmp and not jmp
.org 0x0020              ; memory location of Timer0 overflow handler
rjmp overflow_handler    ; go here if a timer0 overflow interrupt occurs
Reset:
   ldi temp,  0b00000101
   out TCCR0B, temp      ; set the Clock Selector Bits CS00, CS01, CS02 to 101
                         ; this puts Timer Counter0, TCNT0 in to FCPU/1024 mode
                         ; so it ticks at the CPU freq/1024
   ldi temp, 0b00000001
   sts TIMSK0, temp      ; set the Timer Overflow Interrupt Enable (TOIE0) bit
                         ; of the Timer Interrupt Mask Register (TIMSK0)
   sei                   ; enable global interrupts -- equivalent to "sbi SREG, I"
   clr temp
   out TCNT0, temp       ; initialize the Timer/Counter to 0
   sbi DDRB, 5           ; set PD5 to output
; Main body of program:
blink:
   sbi PORTB, 5          ; turn on LED on PD5
   rcall delay           ; delay will be 1/2 second
   cbi PORTB, 5          ; turn off LED on PD5
   rjmp blink            ; loop back to the start
delay:
   clr overflows         ; set overflows to 0
   sec_count:
     cpi overflows,30    ; compare number of overflows and 30
   brne sec_count        ; branch to back to sec_count if not equal
   ret                   ; if 30 overflows have occured return to blink
overflow_handler:
   inc overflows         ; add 1 to the overflows variable
   cpi overflows, 61     ; compare with 61
   brne PC+2             ; Program Counter + 2 (skip next line) if not equal
   clr overflows         ; if 61 overflows occured reset the counter to zero
   reti                  ; return from interrupt
I changed the “.org 0x0020 ; memory location of Timer0 overflow handler”
line to “.org 0x0b00B” per the attiny84 date sheet.
And I changed the DDRB and PORTB to PB0.
When I run the program The LED comes on but never blinks.
Is there a difference between the interrupt handling in the Attiny and the Arduino that I am missing?
JRV31:
But not when you are trying to compile it in the Arduino IDE.
Which IDE or Compiler Environment are you using?
JRV31:
I must admit that I haven’t a clue about assembler programming, but I would bet on it, that the program will not run on an Attiny84 if you do not change this line of your code:
Yes I changed the .inc file to "tn84def.inc"
I am using the AVRA assembler.
