Using Uno as ISP selecting attiny84 @ 8Mhz from tools menu, get the following errors:
Arduino: 1.6.5 (Windows 7), Board: "ATtiny84 (internal 8 MHz clock)"
Error while burning bootloader.
java.lang.NullPointerException
at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:305)
at processing.app.Editor$59.run(Editor.java:2578)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
[code]
Have checked and rechecked wiring connections. All appear to be correct. Am stumped! Any help would be appreciated. Thanks.
Brian
There are a very large number of cores that support attiny84, forked from one of several base cores - so that tells me nothing. Please link to the core you're using.
DrAzzy,
I am easily confused but I will try and understand what you are asking me. Using the Arduino Uno as the ISP I have selected the Attiny84 at 8 Mhz to burn the bootloader. I believe that would be the second choice listing in your post, ATtiny core for x4/x5/x61/x7/x8 series. My original post has the error printout I got when I tried to initiate the burn bootloader. From there, I am lost as to what to do to fix this error. Thanks.
Brian
DrAzzy,
In versions of the Arduino previous to 1.6.0 I believe, it was necessary to retrieve and paste board definitions in the library for the attiny chips. The current version I am using is version 1.6.5 and the board definitions are already included in the drop down box under tools. I do not know which cores are included other than selecting what is available in the drop down box. I have not used previous versions to bootload an Attiny84. However, I have used the previous and current versions to program an Attiny85 successfully with both. How would I go about identifying which Attiny84 core I have? Thanks.
Brian
It's probably whatever you installed for 1.6.0 - since cores and the like get installed in your sketchbook folder (ie, (user)/Documents/Arduino/hardware...), they are not removed when you update the IDE.
