Attiny84 DS3231 Error
Hi, I'm a beginner to Arduino and currently am using Arduino as ISP to program my Attiny84. I'm using DS3231 as an interrupt for certain intervals. Initially, I tried everything successfully interfacing Arduino and DS3231 without Attiny. When I replaced Attiny instead Arduino, I came to know that Wire.h library doesn't support with Attiny. So I searched online and started using the TinyWireM.h library. Since am a noob, am unable to understand the error codes. I have attached my code below and commented my error in the comments. Kindly help me with this.
#include <TinyWireM.h>
#include <ds3231.h>
//#define Wire TinyWireM
volatile boolean interruptActive = false;
int pinLed1 = 7;
int pinLed2 = 0;
int interruptPin = 8;
struct ts t;
uint8_t wake_HOUR;
uint8_t wake_MINUTE;
uint8_t wake_SECOND;
void gotoSleep(void);
 void flash(int pinLed) {
  digitalWrite(pinLed, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(200);                       // wait for a second
  digitalWrite(pinLed, LOW);    // turn the LED off by making the voltage LOW
  delay(200);
//  Serial.begin(9600);
  pinMode(pinLed1, OUTPUT);
  pinMode(pinLed2, OUTPUT);
  pinMode(interruptPin, INPUT_PULLUP);
  TinyWireM.begin();
  DS3231_init(DS3231_CONTROL_INTCN);
  flash(pinLed1);
  flash(pinLed2);
//   attachInterrupt(0, wake, FALLING);
   attachInterrupt(8, wake, FALLING);
  //Disable ADC - don't forget to flip back after waking up if using ADC in your application ADCSRA |= (1 << 7);
  ADCSRA &= ~(1 << 7);
  MCUCR |= (1<<4);
  MCUCR |= (1<<5);
  DS3231_get(&t);
 if (interruptActive) {
  digitalWrite(pinLed1, HIGH);   // turn the LED on (HIGH is the voltage level)
  for (int i = 0;i < 10;i++) {
     flash(pinLed2);
   digitalWrite(pinLed1, LOW);   // turn the LED on (HIGH is the voltage level)
  gotoSleep();
void set_waketime(int minutes)
  DS3231_get(&t);
  wake_SECOND = t.sec + minutes;
  wake_MINUTE = t.min;
  wake_HOUR   = t.hour;
  while (wake_SECOND > 60) {
     wake_MINUTE++;
     wake_SECOND-=60;
  while (wake_MINUTE > 60) {
     wake_HOUR++;
     wake_MINUTE-=60;
  if (wake_HOUR > 24) {
     wake_HOUR -= 24;
void set_alarm1(void)
    // flags define what calendar component to be checked against the current time in order
    // to trigger the alarm - see datasheet
    // A1M1 (seconds) (0 to enable, 1 to disable)
    // A1M2 (minutes) (0 to enable, 1 to disable)
    // A1M3 (hour)    (0 to enable, 1 to disable)
    // A1M4 (day)     (0 to enable, 1 to disable)
    // DY/DT          (dayofweek == 1/dayofmonth == 0)
    uint8_t flags[5] = { 0, 0, 0, 1, 1 };
    DS3231_clear_a1f();
    // set Alarm1
    DS3231_set_a1(wake_SECOND, wake_MINUTE, wake_HOUR, 0, flags);
    // activate Alarm1
    DS3231_set_creg(DS3231_CONTROL_INTCN | DS3231_CONTROL_A1IE);
void wake()
//  flash(pinLed2);
//  flash(pinLed2);
  // cancel sleep as a precaution
//  sleep_disable();
//----------ADCSRA |= (1 << 7);
  interruptActive = true;
  // precautionary while we do other stuff
//---  detachInterrupt(0);
}  // end of wake
void gotoSleep()
  delay(100);
  set_waketime(5);
  set_alarm1();
  //--------------ADCSRA &= ~(1 << 7);
//  set_sleep_mode (SLEEP_MODE_PWR_DOWN);
//  sleep_enable();
// Do not interrupt before we go to sleep, or the
// ISR will detach interrupts and we won't wake.
//  noInterrupts ();
 // will be called when pin D2 goes low
  // We are guaranteed that the sleep_cpu call will be done
  // as the processor executes the next instruction after
  // interrupts are turned on.
//  interrupts ();  // one cycle
   //BOD DISABLE - this must be called right before the __asm__ sleep instruction
   MCUCR = (MCUCR | (1 <<2)) | (1<<7);
   MCUCR = (MCUCR &  ~(1 << 2)) | (1<<7);
__asm__ __volatile__("sleep");
digitalWrite(SDA, 1);
DDA0
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:88:16: note: each undeclared identifier is reported only once for each function it appears in
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:89:16: error: 'SCL' undeclared (first use in this function); did you mean 'SPL'?
digitalWrite(SCL, 1);
SPL
In file included from c:\users\rahul\documents\arduinodata\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\io.h:99:0,
from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:26:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:92:7: error: 'TWSR' undeclared (first use in this function); did you mean 'ACSR'?
cbi(TWSR, TWPS0);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:92:3: note: in expansion of macro 'cbi'
cbi(TWSR, TWPS0);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:92:13: error: 'TWPS0' undeclared (first use in this function); did you mean 'TWSR'?
cbi(TWSR, TWPS0);
cbi(TWSR, TWPS0);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:93:13: error: 'TWPS1' undeclared (first use in this function); did you mean 'TWPS0'?
cbi(TWSR, TWPS1);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:93:3: note: in expansion of macro 'cbi'
cbi(TWSR, TWPS1);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:94:3: error: 'TWBR' undeclared (first use in this function); did you mean 'TWSR'?
TWBR = ((F_CPU / TWI_FREQ) - 16) / 2;
TWSR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:3: error: 'TWCR' undeclared (first use in this function); did you mean 'TWBR'?
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA);
TWBR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:14: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:26: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:38: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_disable':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:114:3: error: 'TWCR' undeclared (first use in this function); did you mean 'EECR'?
TWCR &= ~(_BV(TWEN) | _BV(TWIE) | _BV(TWEA));
EECR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:114:17: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:114:29: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:114:41: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:117:16: error: 'SDA' undeclared (first use in this function); did you mean 'DDA0'?
digitalWrite(SDA, 0);
DDA0
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:118:16: error: 'SCL' undeclared (first use in this function); did you mean 'SPL'?
digitalWrite(SCL, 0);
SPL
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_setAddress':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:130:3: error: 'TWAR' undeclared (first use in this function); did you mean 'EEAR'?
TWAR = address << 1;
EEAR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_setFrequency':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:141:3: error: 'TWBR' undeclared (first use in this function); did you mean 'DWDR'?
TWBR = ((F_CPU / frequency) - 16) / 2;
DWDR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_readFrom':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:204:7: error: 'TWDR' undeclared (first use in this function); did you mean 'DWDR'?
TWDR = twi_slarw;
DWDR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:209:13: error: 'TWCR' undeclared (first use in this function); did you mean 'TWDR'?
} while(TWCR & _BV(TWWC));
TWDR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:209:24: error: 'TWWC' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:210:16: error: 'TWINT' undeclared (first use in this function)
TWCR = _BV(TWINT) | _BV(TWEA) | _BV(TWEN) | _BV(TWIE); // enable INTs, but not START
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:210:29: error: 'TWEA' undeclared (first use in this function); did you mean 'TWWC'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:210:41: error: 'TWEN' undeclared (first use in this function); did you mean 'TWEA'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:210:53: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:213:65: error: 'TWSTA' undeclared (first use in this function); did you mean 'TWEA'?
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA) | _BV(TWINT) | _BV(TWSTA);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_writeTo':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:301:7: error: 'TWDR' undeclared (first use in this function); did you mean 'DWDR'?
TWDR = twi_slarw;
DWDR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:306:13: error: 'TWCR' undeclared (first use in this function); did you mean 'TWDR'?
TWDR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:306:24: error: 'TWWC' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:307:16: error: 'TWINT' undeclared (first use in this function)
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:307:29: error: 'TWEA' undeclared (first use in this function); did you mean 'TWWC'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:307:41: error: 'TWEN' undeclared (first use in this function); did you mean 'TWEA'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:307:53: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:310:65: error: 'TWSTA' undeclared (first use in this function); did you mean 'TWEA'?
TWCR = _BV(TWINT) | _BV(TWEA) | _BV(TWEN) | _BV(TWIE) | _BV(TWSTA); // enable INTs
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_reply':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:5: error: 'TWCR' undeclared (first use in this function); did you mean 'EECR'?
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWINT) | _BV(TWEA);
EECR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:16: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:28: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:40: error: 'TWINT' undeclared (first use in this function); did you mean 'TWIE'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:53: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_stop':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:3: error: 'TWCR' undeclared (first use in this function); did you mean 'EECR'?
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA) | _BV(TWINT) | _BV(TWSTO);
EECR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:14: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:26: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:38: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:50: error: 'TWINT' undeclared (first use in this function); did you mean 'TWIE'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:63: error: 'TWSTO' undeclared (first use in this function)
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_releaseBus':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:3: error: 'TWCR' undeclared (first use in this function); did you mean 'EECR'?
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA) | _BV(TWINT);
EECR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:14: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:26: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:38: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:50: error: 'TWINT' undeclared (first use in this function); did you mean 'TWIE'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_handleTimeout':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:475:29: error: 'TWBR' undeclared (first use in this function); did you mean 'DWDR'?
uint8_t previous_TWBR = TWBR;
DWDR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:476:29: error: 'TWAR' undeclared (first use in this function); did you mean 'TWBR'?
uint8_t previous_TWAR = TWAR;
TWBR
In file included from c:\users\rahul\documents\arduinodata\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\compat\twi.h:36:0,
from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:29:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'TWI_vect':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWSR' undeclared (first use in this function); did you mean 'ACSR'?
switch(TW_STATUS){
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS7' undeclared (first use in this function); did you mean 'TWSR'?
switch(TW_STATUS){
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS6' undeclared (first use in this function); did you mean 'TWS7'?
switch(TW_STATUS){
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS5' undeclared (first use in this function); did you mean 'TWS6'?
switch(TW_STATUS){
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS4' undeclared (first use in this function); did you mean 'TWS5'?
switch(TW_STATUS){
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS3' undeclared (first use in this function); did you mean 'TWS4'?
switch(TW_STATUS){
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:510:7: error: 'TWDR' undeclared (first use in this function); did you mean 'TWSR'?
TWDR = twi_slarw;
TWSR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:530:10: error: 'TWCR' undeclared (first use in this function); did you mean 'TWDR'?
TWCR = _BV(TWINT) | _BV(TWSTA)| _BV(TWEN) ;
TWDR
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:530:21: error: 'TWINT' undeclared (first use in this function)
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:530:34: error: 'TWSTA' undeclared (first use in this function); did you mean 'TWS3'?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:530:46: error: 'TWEN' undeclared (first use in this function); did you mean 'TWINT'?
When you made your original program I assume you worked from examples to learn how to use wire.h, correct?
Have you checked examples for TinyWireM.h to be sure that you are using it correctly?
I am not sure about this case, but not every library can be directly swapped out. In fact that is the exception rather than the norm.
This points up to the previous line in your compiler output to tell you the specific line of code that is in error.
You can see from the path in the error messages that the standard Wire library is still being used, not the TinyWireM library.
Yup I even saw that but I don't know how to make it call the tinywire library
