Dear Arduino Community,
Google wasn't a help.... so this is my question: What is wrong with my Circuit or Code?
Short Description: the ATtiny84 should communicate via FT232RL (origin. FTDI) and using "SoftwareSerial.h" to the Host (PC). Please take a look at the Picture!
Circuit: ATtiny84 with external 16MHz crystal, the ceramic capacitators conncted from crystal pins to GND are 10pF, the ceramic capacitator connected from "DTR" to "/RESET" is 100nF. The resistor connected from "/RESET" to Vcc is 10K.
I flashed the code below by Arduino as ISP successfully (I tested also the standard Blink Sketch and it worked).
The Host (PC, Win 7 x64 prof.) has successfully recognized the FTDI chip and installed the driver successfully.
Result: I get nothing! Not even a corrupted byte!
What I already have tried and did not work:
- Removed R1
- Removed R1, and C3, so DTR was connected directly to /RESET
- Removed R1, C3 and the Wire from DTR to /RESET => so DTR and /RESET were not connected
I also tried other "BAUD" rates below 9600 (also in combination to the list of tries above)... but none of them worked.
I have several FT232RL-Break-Outs, so I changed it... also in combination of diff. BAUD rates and the list of trys above... did also not work.
I am using the same FT232RL-Break-out with ATmega 328P with the same circuit, and it works.
Is there anyone who has already experienced with ATtiny84/44, SoftwareSerial and FT232?
Thank you in forward for your help!
Kindly Regards...
#include <SoftwareSerial.h>
// RX, TX.
SoftwareSerial mySerial( 2, 3 );
mySerial.begin(9600);
mySerial.println("ATtiny84");
