I've got a few attiny84 IC and was testing the blink... using arduino-tiny cores ( Google Code Archive - Long-term storage for Google Code Project Hosting. )
When I flash with 1Mhz , the blink is correct at 1 sec but when I flash using 8Mhz, the blink is NOT blinking at 1 sec ( it was blinking like 8-10 secs slower, timing was totally out )
How do I fix this wrong timing for the 8Mhz attiny84 ?
Thanks
I hv checked the boards.txt, it was as default without any changes...
attiny84at8.name=ATtiny84 @ 8 MHz (internal oscillator; BOD disabled)
# The following DO work (pick one)...
attiny84at8.upload.using=arduino:arduinoisp
attiny84at8.upload.maximum_size=8192
# Default clock (slowly rising power; long delay to clock; 8 MHz internal)
# Int. RC Osc. 8 MHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 64 ms; [CKSEL=0010 SUT=10]; default value
attiny84at8.bootloader.low_fuses=0xE2
attiny84at8.bootloader.high_fuses=0xD7
attiny84at8.bootloader.extended_fuses=0xFF
attiny84at8.bootloader.path=empty
attiny84at8.bootloader.file=empty84at8.hex
attiny84at8.build.mcu=attiny84
attiny84at8.build.f_cpu=8000000L
attiny84at8.build.core=tiny
attiny84at1.name=ATtiny84 @ 1 MHz (internal oscillator; BOD disabled)
attiny84at1.upload.using=arduino:arduinoisp
attiny84at1.upload.maximum_size=8192
# Default clock (slowly rising power; long delay to clock; 8 MHz internal; divide clock by 8)
# Divide clock by 8 internally; [CKDIV8=0]
attiny84at1.bootloader.low_fuses=0x62
attiny84at1.bootloader.high_fuses=0xD7
attiny84at1.bootloader.extended_fuses=0xFF
attiny84at1.bootloader.path=empty
attiny84at1.bootloader.file=empty84at1.hex
attiny84at1.build.mcu=attiny84
attiny84at1.build.f_cpu=1000000L
attiny84at1.build.core=tiny
