ATtiny84 with LIS3DH error with I2C
I have an issue when trying to use the Adafruit LIS3DH library with the ATTinyCore. The error I receive is with initializing the LIS3DH object.
Hopefully someone can help me with resolving this issue. Thanks.
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
// I2C
Adafruit_LIS3DH lis = Adafruit_LIS3DH();
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
   #define Serial SerialUSB
#endif
#define FREEFALL_THRESHOLD 0.35 // g value
#define ACTIVITY_THRESHOLD 1.0  // g value
#define FREEFALL_DEBOUNCE 100   // milliseconds
#define ORIENTATION_THRESHOLD 15  // degrees
Arduino: 1.8.1 (Windows 10), Board: "ATtiny24/44/84, Disabled, ATtiny84, 1 MHz (internal), EEPROM retained, B.O.D. Disabled, Counterclockwise (like old ATTinyCore and x41-series)"
In file included from C:\Users\310\Desktop\Accelerometer Prototype\attiny84_accel\attiny84_accel.ino:1:0:
C:\Users\310\Documents\Arduino\libraries\Adafruit_LIS3DH/Adafruit_LIS3DH.h:112:27: error: expected ')' before '*' token
   Adafruit_LIS3DH(TwoWire *Wi);
C:\Users\310\Documents\Arduino\libraries\Adafruit_LIS3DH/Adafruit_LIS3DH.h:141:3: error: 'TwoWire' does not name a type
   TwoWire *I2Cinterface;
exit status 1
Error compiling for board ATtiny24/44/84.
option enabled in File -> Preferences.
with ATtiny84 you will need to use a different i2c library. something like here:
then maybe something like this in your initilaisation Adafruit_LIS3DH lis = Adafruit_LIS3DH(&TinyWireS);
but not sure this is correct
Fixed last night in the github version (will be in 1.1.6 release). https://github.com/SpenceKonde/ATTinyCore/issues/238 I assumed the person who opened that issue was you, which is why I didn't post back here.
To use the new version now, uninstall using board manager, and refer to the manual installation section of this document: https://github.com/SpenceKonde/ATTinyCore/blob/master/Installation.md
Let me know how you get on with it.
DrAzzy: Fixed last night in the github version (will be in 1.1.6 release). https://github.com/SpenceKonde/ATTinyCore/issues/238 I assumed the person who opened that issue was you, which is why I didn't post back here.
It wasn't me on github. But I'm glad it has been addressed. Thanks.
