ATTiny841 with USBASP
Got my boards (yey!) and soldered the ATTiny841 and an ISP 6 pin header on, plugged it in, selected "ATTiny 441/841 (No bootloader)" from the ATTinyCore options.
Burt the bootloader...no issues. Well..
avrdude: set SCK frequency to 187500 Hz
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
Went to upload a test sketch, and basically go told by avrdude:
Archiving built core (caching) in: /tmp/arduino_cache_695026/core/core_ATTinyCore_avr_attinyx41_chip_841,LTO_disable,clock_8internal,bod_disable_5abd526c3ccd8b9e705611c259fd8f23.a
Sketch uses 384 bytes (4%) of program storage space. Maximum is 8192 bytes.
Global variables use 9 bytes (1%) of dynamic memory, leaving 503 bytes for local variables. Maximum is 512 bytes.
avrdude: AVR Part "attiny841" not found.
*** A LIST OF THE BOARDS FROM AVRDUDE.CONF***
I then apt-get update avedude in the hope it will have the updated conf... Same result.
So what is the issue? Is it my USBASP that needs updating? A new avedude.conf? Bit lost and google seems to have a million suggestions and I don't know which may be my exact problem...
