Attiny85 2kHz PWM
Hi everyone,
I’m trying to use a Attiny85 to interface with a ZIVAN High Frequency Battery charger. For that I need to be able to generat a 2kHz PWM signal.
I have been reading the Attiny85 datasheet and I think it’s possible.
On page 76 you can see that the PWM output frequency can be calculated by the following equation:
fOCnxPWM=fclk_I/0/(N*256)
being N the prescale factor (1, 8, 64, 256 or 1024).
On page 83
you can change this prescaler to clkI/0/8
using:
TCCR0B = TCCR0B & 0b11111000 | 0b010 ;
This means if your clock speed would be 4Mhz you would get a +/-2kHz PWM signal.
On page 34
you can select the clock division factor. Knowing that the attiny85 has an 8MHz internal resonator selecting a division factor 2 would get you the 4MHz needed.
But I don’t know if this is possible or how to change this division factor.
So, if anyone could help me I would appreciate it.
Thanks
Which core are you using?
How accurate does the 2 KHz need to be?
What resolution?
