I have been working in a project that uses an Attiny85 to light some leds using an remote control. I'm using an TSOP2238 to receive the signal.
I used the instructions I found in https://www.instructables.com/id/Attiny-IR-library/
I was able to make it work as I wanted, but I decided to change the (big) Attiny85 8dip with a (little) Attiny85 8soic.
I used
to conect to my Arduino and I pput the same code in the new chip. The code was not working.
Try to know whay happend I used this code:
#include <IRremote.h>
int RECV_PIN = 3;
int red = 0;
int green = 1;
bool r = false;
bool a = false;
IRrecv irrecv(RECV_PIN);
decode_results results;
int entrada;
char binary[33] = {0};
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
irrecv.enableIRIn();
digitalWrite(red, HIGH);
digitalWrite(green, HIGH);
delay(2000);
digitalWrite(red, LOW);
digitalWrite(green, LOW);
if (irrecv.decode(&results)) {
entrada = results.value;
itoa(results.value, binary, 2);
delay(results.value);
//begin sequence light on
//begin sequence light off
for(byte i = 0; i < 33; i++){
if (binary[i] == '0') {
else {
if (binary[i] == '1') {
//end sequence light on
//end sequence light off
irrecv.resume();
delay(100);
I used that code to "decode" the received code from the remote control. I convert the result value to a binary string and I light the leds with the red as o value and the green as 1.
The code in the 8dip works fine, but in the 8soic don't.
The new entry is detected [irrecv.decode(&results) return 1] and the progran begin the "lighting" process, but the result.value is cero. The delay(results.value) is delay(0) because the red led is not seen. And between the begin sequence light and the end sequence light there is only one red light (0 value).
Does anyone have an idea what is happen? Is there any difference between the 2 elements?
Thanks for your time, and any help is wellcome.
