ATTiny85 and I2C
Hi Everyone,
I have asked this question in the wrong section and got no interesting answers....Therefore, I'm asking a different (still similar) question:
Could someone provide me a sketch, that would involve an ATTiny85 that would do the following:
Every 5 seconds, send the following number: 123456 over I2C to address 0x04. (I will figure out the rest of the code !)
I have looked at many threads, I could not come up with a solution. I know I'm downloading to my ATTiny85, because I can make an LED flash, but looking at the SCL & SDA on a scope, nothing is happening....
I have tried a couple of libraries, modified a few sketches (most of those sketches were behaving as a slave)....it simply does not work....frustration level is getting pretty high !!!
I was able to do it with a Nano, but sizewise (and costwise) I need an ATTiny85
Can anyone help me ?
Did you try the TinyWireM library on the ATtiny85
Yes I did...
Found TinyWireM and TinyWireS
must be doing something wrong ...
I just tried the sketch below. Using an Arduino Uno as slave it works as expexted.
/* ATtiny85 as an I2C Master. cpu @ 1MHz
 * ATtiny Pin 5 = SDA
 * ATtiny Pin 7 = SCK
#include <TinyWireM.h>                  // I2C Master lib for ATTiny
unsigned long val=123456;
char buf[7];
void setup(){
  sprintf(buf, "%lu", val);
  TinyWireM.begin();                    // initialize I2C lib
  delay (1000);
void loop(){
  TinyWireM.beginTransmission(4) ; // setup slave's address (7 bit address - same as Wire)
  for (int x=0;x<=(strlen(buf));x++){
    TinyWireM.send(buf[x]) ;      // buffer up bytes to send - can be called multiple times
  byte someByte = TinyWireM.endTransmission();          // actually send the bytes in the buffer
Thanks Erni !
it works !
