Attiny85 and Rh_ask compile error
I’m getting an error when I try to compile some code if I try to include software serial file using the Attiny85. It complies and works on an uno. I know that the attiny85 does not have a serial port this is why I want to use software serial.
Code
   #### TX CODE ####
  Wireless SPI-TRONIC Pro 3600 Digital Protractor
  General Information
  The Pro 3600 has an ASCII-format RS-232 compatible serial port for remote angle readout.
  The T&B Ansley 609-1027 connector on the back of the Pro3600 mates with industry
  standard cables. Angles are calculated and transmitted every 8/15 second (533 msec)
  Angle Output Format:
  The ASCII angle output may be read by a computer, or may directly drive a printer. Measured
  angles cover a full 360° range and the readout is between -180.00° and +180.00°.
  Format:
  <sign> XXX.XX <carriage return><line feed>
  examples:
  + 124.50
  + 32.70
  + 9.38
  - 4.32
  - 179.9
#include <TimedAction.h>
#include <SoftwareSerial.h>
#include <RH_ASK.h>
#ifdef RH_PLATFORM_ATTINY
#include <SPI.h>
#define RH_HAVE_HARDWARE_SPI
#define RH_HAVE_SERIAL
#endif
//RH_ASK driver;
// RH_ASK driver(2000, 4, 5, 0); // ESP8266 or ESP32: do not use pin 11 or 2
RH_ASK driver(2000, 3, 4, 0); // ATTiny, RX on D3 (pin 2 on attiny85) TX on D4 (pin 3 on attiny85),
//# SET UP VARIABLES       #
SoftwareSerial ESPserial(2, 5); // RX | TX
const byte numChars = 9; //Number of bits to get
char receivedChars[numChars];//store the value of imcoming data
uint8_t broadcastAddress[] = {0X8C, 0XAA, 0XB5, 0X7C, 0X76, 0XE9}; //ESP8266 MAC adress been sent to 8C:AA:B5:7C:76:E9
boolean newData = false;
unsigned long NO_Data_in = 0;
#define ECHO_TO_SERIAL 0 //change to zero = no serial output
// constants won't change:
const long interval = 1000;
//RH_ASK driver(2000, 3, 4, 0); // ATTiny, RX on D3 (pin 2 on attiny85) TX on D4 (pin 3 on attiny85),
// interval at which to blink (milliseconds)
//# SET UP STRUCT FOR DATA #
typedef struct Data_struct {
  int PRO3600_Disconnected = 10;
  boolean No_data = false;
  char receivedChars[numChars];   // an array to store the received data
} Data_struct;
Data_struct Data;
byte tx_buf[sizeof(Data)] = {0};
  ESPserial.begin(9600);
  ESPserial.println("<Arduino is ready>");
  if (!driver.init())
    ESPserial.println("init failed");
  // Set device as a Wi-Fi Station
  recvWithEndMarker();
  if (newData ) { //new data received from eLevel
    newData = false;
    Data.PRO3600_Disconnected = 10;
    Data.No_data = false;
    Send_data();
  if (currentMillis - NO_Data_in >= interval) { // one second is more than enough
    // save the last time you blinked the LED
    NO_Data_in = currentMillis;
    Data.PRO3600_Disconnected = 20;
    Data.No_data = true;
    Data.receivedChars[0] = '*';
    Data.receivedChars[1] = ' ';
    Data.receivedChars[2] = '0';
    Data.receivedChars[3] = '.';
    Data.receivedChars[4] = '0';
    Data.receivedChars[5] = '0';
    Data.receivedChars[6] = ' ';
    Send_data();
    //send data outside the while loop
void recvWithEndMarker() {
  static byte ndx = 0;
  char endMarker = '\n';
  char rc;
  if (ESPserial.available() > 0 && newData == false) { // Tried this
    //   while (gtSerial.available() > 0 && newData == false) { //tried this
    NO_Data_in = millis();
    rc = ESPserial.read();
    if (rc != endMarker) {
      Data.receivedChars[ndx] = rc;
      ndx++;
      if (ndx >= numChars) {
        ndx = numChars - 1;
    else {
      Data.receivedChars[ndx] = '\0'; // terminate the string
      ndx = 0;
      newData = true;
      //  receiveUntilTimeout = true; //tried here
void Send_data() {
  memcpy(tx_buf, &Data, sizeof(Data) );
  byte zize = sizeof(Data);
  driver.send((uint8_t *)tx_buf, zize);
  // driver.send((uint8_t *)msg, strlen(msg));
  driver.waitPacketSent();
Ans this is the error
Arduino: 1.8.13 (Windows 10), Board: "ATtiny25/45/85 (No bootloader), Enabled, CPU (CPU frequency), ATtiny85, 8 MHz (internal), EEPROM retained, B.O.D. Disabled (saves power), Enabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Steve\AppData\Local\Arduino15\packages -hardware C:\Users\Steve\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Steve\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Steve\Documents\Arduino\libraries -fqbn=ATTinyCore:avr:attinyx5:LTO=enable,TimerClockSource=default,chip=85,clock=8internal,eesave=aenable,bod=disable,millis=enabled -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Steve\AppData\Local\Temp\arduino_build_739766 -warnings=none -build-cache C:\Users\Steve\AppData\Local\Temp\arduino_cache_375724 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.micronucleus.path=C:\Users\Steve\AppData\Local\Arduino15\packages\ATTinyCore\tools\micronucleus\2.5-azd1b -prefs=runtime.tools.micronucleus-2.5-azd1b.path=C:\Users\Steve\AppData\Local\Arduino15\packages\ATTinyCore\tools\micronucleus\2.5-azd1b -verbose C:\Users\Steve\Documents\Arduino\Pro3600attiny84\Pro3600attiny84.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Steve\AppData\Local\Arduino15\packages -hardware C:\Users\Steve\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Steve\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Steve\Documents\Arduino\libraries -fqbn=ATTinyCore:avr:attinyx5:LTO=enable,TimerClockSource=default,chip=85,clock=8internal,eesave=aenable,bod=disable,millis=enabled -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Steve\AppData\Local\Temp\arduino_build_739766 -warnings=none -build-cache C:\Users\Steve\AppData\Local\Temp\arduino_cache_375724 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.micronucleus.path=C:\Users\Steve\AppData\Local\Arduino15\packages\ATTinyCore\tools\micronucleus\2.5-azd1b -prefs=runtime.tools.micronucleus-2.5-azd1b.path=C:\Users\Steve\AppData\Local\Arduino15\packages\ATTinyCore\tools\micronucleus\2.5-azd1b -verbose C:\Users\Steve\Documents\Arduino\Pro3600attiny84\Pro3600attiny84.ino
Using board 'attinyx5' from platform in folder: C:\Users\Steve\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Using core 'tiny' from platform in folder: C:\Users\Steve\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Warning: Board attiny:attiny:attiny85-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY85-8
Warning: Board attiny:attiny:attiny45-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY45-8
Warning: Board attiny:attiny:attiny85 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY85
Warning: Board attiny:attiny:attiny44 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY44
Warning: Board attiny:attiny:attiny45 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY45
Warning: Board attiny:attiny:attiny84-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY84-8
Warning: Board attiny:attiny:attiny84 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY84
Warning: Board attiny:attiny:attiny84-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY84-20
Warning: Board attiny:attiny:attiny45-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY45-20
Warning: Board attiny:attiny:attiny85-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY85-20
Warning: Board attiny:attiny:attiny44-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY44-8
Warning: Board attiny:attiny:attiny44-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY44-20
Detecting libraries used...
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\sketch\\Pro3600attiny84.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for TimedAction.h: [TimedAction]
ResolveLibrary(TimedAction.h)
  -> candidates: [TimedAction]
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\sketch\\Pro3600attiny84.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SoftwareSerial.h: [espsoftwareserial-master@6.12.1 SoftwareSerial@1.0.0]
ResolveLibrary(SoftwareSerial.h)
  -> candidates: [espsoftwareserial-master@6.12.1 SoftwareSerial@1.0.0]
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\sketch\\Pro3600attiny84.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for RH_ASK.h: [RadioHead]
ResolveLibrary(RH_ASK.h)
  -> candidates: [RadioHead]
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\sketch\\Pro3600attiny84.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@2.0.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@2.0.0]
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\sketch\\Pro3600attiny84.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction\\TimedAction.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial\\SoftwareSerial.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHCRC.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHDatagram.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHGenericDriver.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHGenericSPI.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHHardwareSPI.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHMesh.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHNRFSPIDriver.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHReliableDatagram.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHRouter.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHSPIDriver.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RHSoftwareSPI.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_ASK.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_NRF24.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_NRF905.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_RF22.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_RF24.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_RF69.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_RF95.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_Serial.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_TCP.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI\\SPI.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\sketch\\Pro3600attiny84.ino.cpp" -o "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\sketch\\Pro3600attiny84.ino.cpp" -o "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\sketch\\Pro3600attiny84.ino.cpp.o"
Compiling libraries...
Compiling library "TimedAction"
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\TimedAction\TimedAction.cpp.o
Compiling library "SoftwareSerial"
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\SoftwareSerial\SoftwareSerial.cpp.o
Compiling library "RadioHead"
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHCRC.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHDatagram.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHGenericSPI.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHGenericDriver.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHHardwareSPI.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHNRFSPIDriver.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHMesh.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHReliableDatagram.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHSPIDriver.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RH_ASK.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RH_NRF905.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHRouter.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RH_RF24.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RH_NRF24.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RH_RF69.cpp.o
"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10813 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\TimedAction" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SoftwareSerial" "-IC:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Steve\\Documents\\Arduino\\libraries\\RadioHead\\RH_Serial.cpp" -o "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_739766\\libraries\\RadioHead\\RH_Serial.cpp.o"
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RH_RF95.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RH_TCP.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RHSoftwareSPI.cpp.o
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_739766\libraries\RadioHead\RH_RF22.cpp.o
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp: In member function 'virtual bool RH_Serial::available()':
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:28:27: error: invalid use of incomplete type 'class HardwareSerial'
     while (!_rxBufValid &&_serial.available())
In file included from C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:6:0:
C:\Users\Steve\Documents\Arduino\libraries\RadioHead/RH_Serial.h:36:7: note: forward declaration of 'class HardwareSerial'
 class HardwareSerial;
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:29:11: error: invalid use of incomplete type 'class HardwareSerial'
  handleRx(_serial.read());
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp: In member function 'virtual bool RH_Serial::send(const uint8_t*, uint8_t)':
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:166:5: error: invalid use of incomplete type 'class HardwareSerial'
     _serial.write(DLE); // Not in FCS
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:167:5: error: invalid use of incomplete type 'class HardwareSerial'
     _serial.write(STX); // Not in FCS
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:177:5: error: invalid use of incomplete type 'class HardwareSerial'
     _serial.write(DLE);
     _serial.write(DLE);
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:179:5: error: invalid use of incomplete type 'class HardwareSerial'
     _serial.write(ETX);
     _serial.write(ETX);
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:183:5: error: invalid use of incomplete type 'class HardwareSerial'
     _serial.write((_txFcs >> 8) & 0xff);
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:184:5: error: invalid use of incomplete type 'class HardwareSerial'
     _serial.write(_txFcs & 0xff);
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp: In member function 'void RH_Serial::txData(uint8_t)':
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:191:2: error: invalid use of incomplete type 'class HardwareSerial'
Multiple libraries were found for "SoftwareSerial.h"
 Used: C:\Users\Steve\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\libraries\SoftwareSerial
 Not used: C:\Users\Steve\Documents\Arduino\libraries\espsoftwareserial-master
C:\Users\Steve\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp:192:5: error: invalid use of incomplete type 'class HardwareSerial'
     _serial.write(ch);
     _serial.write(ch);
Using library TimedAction in folder: C:\Users\Steve\Documents\Arduino\libraries\TimedAction (legacy)
Using library SoftwareSerial at version 1.0.0 in folder: C:\Users\Steve\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\libraries\SoftwareSerial
Using library RadioHead in folder: C:\Users\Steve\Documents\Arduino\libraries\RadioHead (legacy)
Using library SPI at version 2.0.0 in folder: C:\Users\Steve\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\libraries\SPI
exit status 1
Error compiling for board ATtiny25/45/85 (No bootloader).
