Attiny85 and servo
I have been playing around with the attiny the last week, and I am very impressed with how easy it is.
I am using this tutorial : http://hlt.media.mit.edu/wiki/pmwiki.php?n=Main.ArduinoATtiny4585
I have tried the blink, fade and potmeter sketches with nio problem, and now I would try a servo sketch using the SoftwareServo. But it only works partly, I can move the servo either by using a potmeter, or by coding with fixed values as below, but either way the servo jitters, it is moving like it should but it jitters.
My guess is that the pwm freqense is wrong, it should be 50HZ, but as far as I know on the Arduino Uno it is about 400HZ, and the servo runs smooth anyway.
I am not using a external x-tal, and I don't have an oscilloscop to measure the frequence
(I don't know how to hit the # , where and when should I do it)
Any suggestions.
#include <SoftwareServo.h>
SoftwareServo servo;
int potpin = 3;
int val;
long previousMillis = 0;        // will store last time LED was updated
long interval = 100;           // interval at which to blink (milliseconds)
 pinMode(1, OUTPUT);
 pinMode(3, INPUT);
 servo.attach(1);
    val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
    val = map(val, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
 if(currentMillis - previousMillis > interval) {
    servo.write(val);    // sets the servo position according to the scaled value
    SoftwareServo::refresh();
 } //if
} //loop
By that do you mean you don't know where the # button is? The button that inserts code tags?
Or do you mean something regarding the C preprocessor?
Lift the clock at 8mhz by fuse programming.
just remove the default 8x clock divider .
BrainBooster
Thanks, I tryed to edit this entry in boards.txt
attiny85arduinoisp.build.mcu=attiny85
attiny85arduinoisp.build.f_cpu=1000000
to
f_cpu=8000000
But then I get this error message in the Arduino IDE
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I know I don't know enough about programming fuses just yet, so maybe I will wait till I get older and Wiser XD
Coding Badly
Sorry wasn't clear, what I meant was: when I copy a sketch from the IDE to the forum I use Edit->Copy for forum
I know there is a better way involving the # sign, but I dont't know where I am supposed to use it
I vaguely recall that there are problems with Copy for Forum.
Does this help...
Please click Modify ( or ) on your post, select the source code, click the button above the edit window, then click .
editing the board.txt file is not enough to make the tiny run faster.
if you are going to play with other mcu than the atmega328, you have to know how the fuses systm work.
anyway, the board.txt file was correct to deal with virgin attiny85 as the have a native 1mhz clock, so don't alter it.
You can use software servo library :slight_smile:
http://www.arduino.cc/playground/ComponentLib/Servo
These two...
...are mutually exclusive. You can use SoftwareServo --OR-- you can use delay but you cannot use both. You will have to use the BlinkWithoutDelay technique...
i have changed the sketch to use millis instead of delay(), but the servo is still jittering, it can't hold a position,it moves a little all the time.
(but I have found the # sign )
Thanks for the help, i don't think it can be better until I find out about the fuse programming.
Erni:
With this core changing the fuses is very easy (Tools / Burn Bootloader from the IDE)...
http://code.google.com/p/arduino-tiny/
Some instructions here...
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1285218245/0#0
More stuff here...
http://arduino.cc/forum/index.php/topic,51984
Thank you Coding Badly.
I have installed your core. First I tried with som small sketches like blink and fade, that worked fine, no problem
Then I tried to change the clock freq. to 8 MHz using your procedure (burning bootloader):
Doing so gives me the following error:
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
avr_read(): error reading address 0x0000
read operation not supported for memory "lock"
avrdude: failed to read all of lock memory, rc=-2
I have read elsewere that In can ignore the first 2 lines (I got the same error using the HLT core)
But the last 3 lines I don't understand. A wild guess: Does it only work with a virgin Chip? or is something else wrong.
I bought a very old (and very cheap) oscilloscop and as far as I can read it the PWM signal is high for 1 second and low for 1 sek, at 50% dutycycle, so that seems to indicate that I am right assuming that the servo jitter is due to a wong PWM freq. (the PWM signal should be between 1 and 2 ms)
Another rather funny observation: If I just use the attiny 8 mhz option when uploading a sketch it just slows the freq. down, f.ex the blink example gets maybe 8 ? times slower.
Thank you for you time
Erni:
You are welcome.
Yes. You can ignore the PAGEL / BS2 warnings.
The avrdude.conf needs a small modification. Give these a read...
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274820597/99#99
Thanks again Coding Badly
I made the modification in avrdude.conf and now my attiny are running 8 Mhz.
