In the following code, the fading of the LED works fine. When /LOCK goes low, the LED goes out, as it should. However, It doesn't seem as if the interrupt to blink the LED is working. I am a bit confused as to the proper designation for the INT0 pin. It is digital pin 2 (physical pin 7), but examples I see of attachInterrupt all use the "0" designator, indicating INT0. Which is correct?
BTW, I have this breadboarded up for testing. It is not connected to the rubidium yet. I am simulating the inputs with alligator clips to 5V or GND, as appropriate.
I'm using 1.6.0 RC1.
// Use an ATtiny85 to control an LED based on inputs from an FE-5680A rubidium frequency reference.
// To support ATtiny in the Arduino IDE, I used the following with 1.6.0 RC1:
// http://www.leonardomiliani.com/en/2014/aggiornato-il-core-attiny-per-lide-1-5-8-di-arduino/
// I found the LED fade routine on the Arduino Forum.
// December 2014 by Joseph Gray W5JG
// Inputs:
// Pin INT0 (physical pin 7) = PPS from rubidium. 1 uS pulse. May need a pulse stretcher to reliably see this
// every time. This pin may need a pulldown resistor to keep the input from floating. 10 K should work.
// Pin 3 (physical pin 2) = /LOCK from rubidium. Goes LOW when locked. Use the internal pullup resistor.
// Outputs:
// Pin 1 (physical pin 6) = PWM to LED. Don't forget a current limiting resistor. 1 K or so is good.
// This work is licensed under a Creative Commons Attribution-ShareAlike 4.0 International License.
const byte ppsPin = 0; // INT0 pin.
const byte lockPin = 3; // Digital I/O pin.
const byte ledPin = 1; // One of two PWM pins on the ATtiny85.
const int period = 3000; // Three second fade interval.
boolean isr = false; // Flag to tell us if the ISR is enabled.
int value; // Value to PWM LED with.
long time = 0; // Holds milliseconds since program start.
pinMode(ppsPin, INPUT); // PPS from rubidium.
pinMode(lockPin, INPUT_PULLUP); // /LOCK from rubidium.
pinMode(ledPin, OUTPUT); // PWM to LED.
while(digitalRead(lockPin) == HIGH){ // Fade LED in/out while the rubidium is warming up.
if (isr == true){
detachInterrupt(ppsPin); // Disable ISR if we don't have lock. Fade LED instead of blink.
time = millis(); // Get the current time since program start.
value = 128 + 127 * cos(2 * PI / period * time); // Using cosine gives smoother fade.
// Circular function does fade in/out.
analogWrite(ledPin, value); // Sets PWM value from 0 to 255.
// Rubidium has lock, so stop fading LED.
digitalWrite(ledPin, LOW); // Turn LED off.
if (isr == false){ // Setup ISR to detect PPS.
attachInterrupt(ppsPin, blinkLED, RISING); // Interrupt on rising edge of PPS.
isr = true; // Set flag so we know we have enabled the ISR.
void blinkLED() {
digitalWrite(ledPin, HIGH); // Turn the LED on.
delayMicroseconds(500000); // This is usable inside the ISR.
digitalWrite(ledPin, LOW); // Turn the LED off.
