I would like to show a bitmap on an oled and power the project with a CR2032 battery. I have searched the internet for a while and it's hard to find information.
If someone kind could point me in the right direction I would be very grateful:)
(Maybe the ATtiny85 is not the way to go?, I checked out Digisparks ATtiny but it requires 5V)
Yes I have searched and it looks like it is possible since people are using the tiny85 for a lot of projects. Like this one
So it should work with a button cell.
Application is just to use the minimum amount of parts and code to make a standalone compact stack of a Battery, Microprocessor and an Oled-display that can store an image.
There are projects like this one: This project uses the ATtiny85 from digispark. But as I mentioned earlier it needs 5v.
It would, but briefly. Don't underestimate the power requirements of an OLED. It'll drain a button cell in no-time.
In itself an ATtiny85 runs fine on 3.3V. You could modify a Digispark module to run on 3.3V, but frankly, I'd just start over and make one yourself; it would allow you to keep the parts count down to the bare minimum as you desire while also minimizing physical footprint (I assume this is relevant since you intend to use a button cell).
However, in any case, a button cell paired with an OLED is not something that will have much practical relevance given the short run time it will allow. Kind of a waste of perfectly good button cells, too.
These guys over at Tiny Circuits uses a LITHIUM ION POLYMER BATTERY - 3.7V 290MAH and that is probably a better solution(?). I then have to make use of the "JST SH connector" and also get a recharger.
Yep, that may work. You can get an estimate of how long the battery may last by determining how much current the display draws. It depends on what you show on it of course, so it'll be a ballpark figure only. But with 290mAh you'll get at least some running time before it goes dead.
