Thanks Every body for Suggestions.
I agreed my line "Need help to solve power issue for hearing Aid" caused confusion. All I am trying is to convert 3.7 volts of Lo-Po battery to hearing aid compatible 1.47 volt.
I calculated efficiency of different solutions and results are following
Assumptions: Some values are rounded to keep calculation simple.
Battery minimum voltage = 3v
battery max Voltage = 4v
I load = 3mA
Vload = 1.7 v
**1. **** at 100 % efficiency using black magic **
Battery capacity = 3.7 v * 1000mAh = 3700mWh
load power = 3A*1.7v = 5.1mW
@ 100 % efficiency
time = 3700/5.1 = 725h = 30 days not bad
2. using LM317 linear voltage regulator
if V battery = 3v
I in = 9mA
V load 1.7V
I load = 3mA
Efficiency = (31.7)/(39) = 18%
expected battery life = 30 Days * 0.18 = 5.14 days
if V battery = 4v
I in = 9.67 mA
V load = 1.85 v
I out = 3mA
Efficiency = (1.853)/(9.674) = 8.59 %
Expected battery life = 30days * 0.085 = 2.41days
3. using Attiny85 **
Current required to power Tiny = 2mA
At 4v
Power required for tiny = 8mW
let suppose Switching circuit and LC filter is 80 % efficient and 20 % is loss in heat
total power input = 8mW + 80% 5.1 mW = 12mW
efficiency = 8/12 = 66.6 %
Expected life = 19 Days ** Attiny85 based buck converter is higher efficient linear one.*
**4. RT8059 Buck IC ** Luckily I found this IC near me.
Datasheet claims 95% efficiency
Suppose effective efficiency is 90 % after loss in LC FIlter
Expected battery life = 80 * 0.9 = 27 days
5. Zener based voltage regulator
I think zener Would have same efficiency as LM317 or may be Worst.
This li-po battery won't hang in ear. It will be in pocket a thin wire will carry power to hearing and will also keep it captive. Of course I am planned to used Battery management system and A poly fuse to prevent Battery damage and Potential problem. also order some Zener diodes to clip any over shot in voltage.
Let me Know What you guys think and thanks for suggestions.
