hole
1
Hi!
I use ATtiny from Google Code Archive - Long-term storage for Google Code Project Hosting. (Google Code Archive - Long-term storage for Google Code Project Hosting.) and try to implement a timer interrupt. This small test program shall blink on pin 1 with 0,5 Hz and do some higher frequent stuff on pin 0. Hardware is ATtiny85 at 8 MHz. Bootlooader burned.
It works really fine if I don't do the "setupisr();". Blinks like a charm. If I do it, all hell breaks lose on Pin 1 and 0.
"Burnbootloader" burned
#include <avr/io.h>
#include <avr/interrupt.h>
const byte PinLEDgreen = 0;
const byte PinLEDblue = 1;
void setupisr() {
cli();
TCCR0A = 0;
TCCR0B = 0;
// set up Timer 0
TCCR0B |= bit (CS00) | bit (CS02); // Prescaler 1024
TCCR0A |= bit (WGM01); // Timer 0 in CTC mode
OCR0A = 127; // CTC Compare value (count up to 128)
TIMSK = (1<<OCIE0A);
sei();
ISR(TIMER0_COMPA_vect)
cli();
digitalWrite(PinLEDgreen, ! digitalRead(PinLEDgreen));
sei();
pinMode(PinLEDgreen, OUTPUT);
pinMode(PinLEDblue, OUTPUT);
setupisr();
void loop(){
digitalWrite(PinLEDblue,HIGH);
digitalWrite(PinLEDblue,LOW);
Anyone sees my error? Any hints? Any ideas?
(Goal is to get the OneWire lib running on ATtiny85 and have timer interrupts...)
Thanks!
cli(); // <<<<< Bad idea. Remove this line.
sei(); // <<<<< Bad idea. Remove this line.
hole
3
Does not change anything. I removed all sei()/cli().
Without setupisr(); I get something about 0,5 Hz at Pin 1 and nothing at Pin 0
Adding setupisr(); I get about 15 Hz at Pin 1 and about 30 Hz at Pin 0.
Disabling Timer1 gives the expected 30 Hz at Pin 0 and (of course) nothing on Pin 1.
Erni
4
This should work, the only differense is this line:
TCCR0A |=(1<<COM0A1); //Timer0 in toggle mode Table 11.2
const byte led4 = 4;
const byte led3 = 3;
volatile int count = 0;
void setup(){
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
cli();
TCCR0A = 0;
TCCR0B = 0;
TCCR0A |=(1<<WGM01); //Start timer 1 in CTC mode Table 11.5
TCCR0B |= (1 << CS02) | (1 << CS00); // Prescaler =1024 Table 11.6
OCR0A=127; //CTC Compare value
TIMSK |= (1 << OCIE0A);
sei();
count++;
if (count>30){
digitalWrite(led4, ! digitalRead(led4));
count=0;
void loop(){
digitalWrite(led3,HIGH);
digitalWrite(led3,LOW);
hole
5
Thanks Erni,
it really works.
Could you explain what happens? I read the PDF but I don't see the reason....
Thanks!
Erni
6
That was not a good example, sorry.
The below example works, it seems that the order of the commands are important.
void setup(){
cli();
TCCR0A = 0;
TCCR0B = 0;
TIMSK |= (1 << OCIE0A); //Enable CTC interrupt see 13.3.6
sei();
count++;
if (count>30){
count=0;
void loop(){
