Hi! I'm trying to program an ATTiny85 chip to detect a 2 lead push button, so that when it's not being pressed, it should turn on the LED and keep it on. But when it does get pressed, it should turn off the LED, and play a song on a loudspeaker. Currently, I can't seem to get the button to work, because it doesn't affect the LED at all, and doesn't seem to be resetting the song. I feel that I'm overlooking something so simple (especially when it's just about a push button), and it's a bit embarrassing to admit. I'm not sure whether it's a programming issue, or the way I've connected the components on the breadboard.
There are no problems with uploading the code to the ATTiny85 using the Arduino as the programmer if you're wondering.
Here is what the breadboarding looks like (LED connected to pin 7, push button on pin 2):
Here is the part of the code that is relevant to the question (I'm not even sure if it resets the song to be honest):
const int led = 2;
const int button = 3;
void setup(){
pinMode(button, INPUT);
pinMode(led, OUTPUT);
void loop(){
int button_state = digitalRead(button);
if (button_state == LOW){
digitalWrite(led, HIGH); // Turn LED on if button is not pressed
digitalWrite(led, LOW); // Turn LED off if button is pressed
TunePtr = 0; // Reset song
Chan = 0;
delay(10000); // Allow song to play fully
Here is what the whole code should look like:
/* Digital Music Box v2
David Johnson-Davies - www.technoblogy.com - 16th March 2016
ATtiny85 @ 16 MHz (internal PLL; 4.3 V BOD)
CC BY 4.0
Licensed under a Creative Commons Attribution 4.0 International license:
http://creativecommons.org/licenses/by/4.0/
int Scale[] = {
680, 721, 764, 809, 857, 908, 962, 1020, 1080, 1144, 1212, 1284,
1361, 1442, 1528, 1618, 1715, 1817, 1925, 2039, 2160, 2289, 2425, 2569,
2722, 2884, 3055, 3237, 3429, 3633, 3849, 4078 };
const int Channels = 4;
const int Tempo = 4; // 4 = 4 beats per second
const int Decay = 9; // Length of note decay; max 10
const int led = 2;
volatile unsigned int Acc[Channels];
volatile unsigned int Freq[Channels];
volatile unsigned int Amp[Channels];
// Play Happy Birthday
const uint32_t Tune[] PROGMEM = {
//_*_*__*_*_*__*_*__*_*_*__*_*__*_ff
//C D EF G A BC D EF G A BC D EF G
0b00000000000000000001000000000000,
0b10000000000000000000010000000000,
0b00000000000000000000000000000000,
0b00001001000000000001000000000000,
0b00000000000000000000000010000000,
0b00100000000000000000000100000000,
0b00000101000000000000000000000000,
0b00000101000000000001000000000000,
0b00000000000000000000000000100000,
0b10000000000000000000000010000000,
0b00001001000000000000000000000000,
0b10000000000000000000000000000001,
0b00100000000000000000000000001000,
0b00001000000000000000000010000000,
0b00000100000000000000000100000000,
0b00000000000000000000010000000000,
0b00000000000000000000000000000100,
0b00000001000000000000000000001000,
0b00000101000000000000000000100000,
0b10001001000000000000000010000000,
0xFF}; // End of tune
//Globals persist throughout tune
int TunePtr = 0, Chan = 0;
// Watchdog interrupt plays notes
ISR(WDT_vect) {
sei(); // Allow interrupts
WDTCR |= 1<<WDIE;
unsigned long Chord = pgm_read_dword(&Tune[TunePtr]);
if (Chord == 0xFF) return;
TunePtr++;
// Read the bits in Chord
for (int Note = 0; Note < 32; Note++) {
if ((Chord & 0x80000000) != 0) {
Freq[Chan] = Scale[Note];
Amp[Chan] = 1<<(Decay+5);
Chan = (Chan + 1) % Channels;
Chord = Chord<<1;
// Generate square waves on 4 channels
ISR(TIMER0_COMPA_vect) {
signed char Temp, Mask, Env, Note, Sum=0;
for (int c = 0; c < Channels; c++) {
Acc[c] = Acc[c] + Freq[c];
Amp[c] = Amp[c] - (Amp[c] != 0);
Temp = Acc[c] >> 8;
Mask = Temp >> 7;
Env = Amp[c] >> Decay;
Note = (Env ^ Mask) + (Mask & 1);
Sum = Sum + Note;
OCR1B = Sum + 128;
// Enable 64 MHz PLL and use as source for Timer1
PLLCSR = 1<<PCKE | 1<<PLLE;
// Set up Timer/Counter1 for PWM output
TIMSK = 0; // Timer interrupts OFF
TCCR1 = 1<<CS10; // 1:1 prescale
GTCCR = 1<<PWM1B | 2<<COM1B0; // PWM B, clear on match
OCR1B = 128;
DDRB = 1<<DDB4; // Enable PWM output on pin 4
// Set up Timer/Counter0 for 20kHz interrupt to output samples.
TCCR0A = 3<<WGM00; // Fast PWM
TCCR0B = 1<<WGM02 | 2<<CS00; // 1/8 prescale
OCR0A = 99; // Divide by 100
TIMSK = 1<<OCIE0A; // Enable compare match, disable overflow
// Set up Watchdog timer for 4 Hz interrupt for note output.
WDTCR = 1<<WDIE | Tempo<<WDP0; // 4 Hz interrupt
TunePtr = 0;
Chan = 0;
delay(10000);
For reference, the music box code is from here, but the LED, push button, and song reset code is my own coding: http://www.technoblogy.com/show?11TQ
