Attiny85 digital input (read faster - direct)
I am trying to read a clocked signal via pin change interrupt (clock on PB2 - Int0) and read the data on PB1 or (d1 Arduino pin) The "digitalRead(buttonPin)" looks to be too slow. I am trying to do a more direct approach. What would be the correct way to do this? Is "PINB & _BV(PB1)" the correct way to do this?
DaOne:
I am trying to read a clocked signal via pin change interrupt (clock on PB2 - Int0) and read the data on PB1 or (d1 Arduino pin) The “digitalRead(buttonPin)” looks to be too slow. I am trying to do a more direct approach. What would be the correct way to do this? Is “PINB & _BV(PB1)” the correct way to do this?
‘PINB & 2’ will work. If there’s a define for PB1, what you wrote will work. I forget if is defined as 1 as it would have to be for that too work ( _BV(x) is just 1<<x )
That will give you 2 if the pin is high, 0 if not. (So you can’t compare to HIGH but you can use it add the test (ie, if (PINB&2) will run if that pin reads high, but if ((PINB&2)==HIGH) won’t.
I am trying to build a string of 1s and 0s based on the the state of the data input pin when the clock falls.
So does this look correct?
mySensVals[countClock] = (PINB&2);
Actually from the looks of it the interrupt is on PB2. I would like to use PB1 (pin 6 on the micro)
so I wanna replace...
mySensVals[countClock] = digitalRead(1);
with
mySensVals[countClock] = (PINB&1);
correct?
DaOne: Actually from the looks of it the interrupt is on PB2. I would like to use PB1 (pin 6 on the micro)
correct?
Nope.
PINB&1 looks at bit zero (the ones place), which I'd for PB0. You want to look at bit 1, corresponding to PB1, so PINB&2
I think I understand now. Its always 1 higher than the pin number. So I would be using...
to read pin PB1
correct?
Thank you for your help.
It is 2^n, where n is bit number, zero indexed.
Or 1<<n
Worked perfectly. Thank you again.
