Hi to everyone!
That's my first post here.
I'm trying to write presaved messages controling a digispark attiny85 using i2c communication with an esp01 in AP mode to control the system via smartphone.
Doing some tests I can now do everything I wanted to do but now, after adding the DigiKeyboard commands and lib, when I tried uploading the code I got this error..
C:\Users\10293_~1\AppData\Local\Temp\arduino_build_994554\libraries\TinyWire-master\twi.cpp.o: In function `__vector_2':
C:\Users\10293_000\Documents\Arduino\libraries\TinyWire-master/twi.cpp:822: multiple definition of `__vector_2'
C:\Users\10293_~1\AppData\Local\Temp\arduino_build_994554\libraries\DigisparkKeyboard\usbdrvasm.S.o:C:\Users\10293_000\Documents\ArduinoData\packages\digistump\hardware\avr\1.6.7\libraries\DigisparkKeyboard/usbdrvasm165.inc:41: first defined here
collect2.exe: error: ld returned 1 exit status
Using library DigisparkKeyboard in folder: C:\Users\10293_000\Documents\ArduinoData\packages\digistump\hardware\avr\1.6.7\libraries\DigisparkKeyboard (legacy)
Using library TinyWire-master in folder: C:\Users\10293_000\Documents\Arduino\libraries\TinyWire-master (legacy)
exit status 1
Error compiling for board Digispark (Default - 16.5mhz).
Can someone help me to solve this pls?
Here's also the attiny85 code (I don't think it's a problem related to the esp01 code so i think that the attiny85 one could be enough)
#include "KeyboardIT.h"
#include <TinyWire.h>
#define own_address 9
TinyWire.begin(own_address);
TinyWire.onReceive(comando);
pinMode(0, OUTPUT); //LED on Model B
pinMode(1, OUTPUT); //LED on Model A or Pro
void comando(int dato)
while (TinyWire.available())
char c = TinyWire.read();
if(c=='1')
digitalWrite(0, HIGH);
digitalWrite(1, HIGH);
else if(c=='2')
DigiKeyboard.sendKeyStroke(0);
DigiKeyboard.delay(2000);
DigiKeyboard.sendKeyStroke(KEY_H);
DigiKeyboard.sendKeyStroke(KEY_E);
DigiKeyboard.sendKeyStroke(KEY_L);
DigiKeyboard.sendKeyStroke(KEY_O);
for(;;){ /empty/ }
else if(c=='0')
digitalWrite(0, LOW);
digitalWrite(1, LOW);
