Attiny85 EEPROM to store last pattern in case of power loss
hi guys, looking to implement the above any help how to do it?
#include <EEPROM.h>
  WS2811/Neopixel pattern switcher for ATtiny85 (and Arduino)
  Requires Adafruit NeoPixel Library
  WS2811 Signal, Digital Pin 4
  Button, Digital Pin 0
  GPL v3
// Define
#define NUM_LEDS 2
#define DATA_PIN 4
#define BTN_PIN 0
#define BTN_DELAY 250
#define NUM_PATTERNS 10
#define CTR_THRESH 16
// Init Vars
uint8_t j = 0;
uint8_t pattern = 1;
uint8_t buttonState = 0;
uint8_t lastPix = 0;
uint8_t myPix = 0;
uint8_t direction = 1;
uint8_t counter = 0;
uint8_t colors[3];
uint32_t setColor = 0;
unsigned long mark;
// Start Strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, DATA_PIN, NEO_GRB + NEO_KHZ800);
  pinMode(BTN_PIN, INPUT);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // if button pressed, advance, set mark
  chkBtn(digitalRead(BTN_PIN));
  // if pattern greater than #pattern reset
  if (pattern > NUM_PATTERNS)
    pattern = 1;
  // choose a pattern
  pickPattern(pattern);
  // set direction
  if (direction == 1) {
    j++;
    j--;
  if (j > 254) {
    direction = 0;
  if (j < 1) {
    direction = 1;
/* pick a pattern */
void pickPattern(uint8_t var) {
  switch (var) {
    case 1:
      // scanner, color and delay - RGB
      scanner(strip.Color(255, 0, 0), 50);
      scanner(strip.Color(200, 0, 100), 50);
      scanner(strip.Color(64, 0, 200), 50);
    case 2:
      // color wipe random RGB
      colorWipe(strip.Color(random(255), random(255), random(255)), 50);
    case 3:
      // color wave - Hue/Sat/Bright
      // hue low (0-359), high (0-359),rate,extra delay
      wavey(200, 240, 0.06, 0);
    case 4:
      // rainbow firefly, 1px at random
      colorFirefly(60);
      counter++;
    case 5:
      // rainbow solid
      rainbow(10);
      counter++;
    case 6:
      // bounce in and out
      // tail len, counter, delay
      bounceInOut(4, counter, 20);
      counter++;
    case 7:
      // color wipe from center
      colorWipeCenter(strip.Color(255, 0, 0), 100);
      colorWipeCenter(strip.Color(255, 64, 0), 100);
    case 8:
      // solid color
      colorFast(strip.Color(255, 255, 255), 0);
    case 9:
      // fade even or odd
      // 0-359 Hue value, even/odd, delay
      fadeEveOdd(200, 0, 20);
      fadeEveOdd(300, 1, 20);
    case 10:
      // show rainbow
      rainbowCycle(10);
/* check button state */
boolean chkBtn(int buttonState) {
  if (buttonState == HIGH && (millis() - mark) > BTN_DELAY) {
    j = 0;
    mark = millis();
    pattern++;
    return true;
  else {
    return false;
void colorFirefly(int wait) {
  if (myPix != lastPix) {
    if (counter < CTR_THRESH) {
      float colorV = sin((6.28 / 30) * (float)(counter)) * 255;
      HSVtoRGB((359 / CTR_THRESH)*counter, 255, colorV, colors);
      strip.setPixelColor(myPix, colors[0], colors[1], colors[2]);
      strip.show();
      delay(wait);
      lastPix = myPix;
      counter = 0;
      colorFast(0, 0);
    myPix = random(0, strip.numPixels());
// Fill the dots one after the other with a color
// Modified from Neopixel sketch to break on button press
void colorWipe(uint32_t c, uint8_t wait) {
  for (uint16_t i = 0; i < strip.numPixels(); i++) {
    if (chkBtn(digitalRead(BTN_PIN))) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void colorWipeCenter(uint32_t c, uint8_t wait) {
  uint8_t mid = strip.numPixels() / 2;
  strip.setPixelColor(mid, c);
  for (uint16_t i = 0; i <= strip.numPixels() / 2; i++) {
    strip.setPixelColor(mid + i, c);
    strip.setPixelColor(mid - i, c);
    strip.show();
    delay(wait);
// fast version
void colorFast(uint32_t c, uint8_t wait) {
  strip.show();
  delay(wait);
// Rainbow Cycle, modified from Neopixel sketch to break on button press
void rainbowCycle(uint8_t wait) {
  uint16_t i;
  //  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
  for (i = 0; i < strip.numPixels(); i++) {
    strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
  strip.show();
  delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i;
  //for(j=0; j<256; j++) {
    strip.setPixelColor(i, Wheel((i + j) & 255));
  strip.show();
  delay(wait);
// scanner
void scanner(uint32_t c, uint8_t wait) {
  for (int i = 0; i < strip.numPixels(); i++) {
    colorFast(0, 0);
    strip.show();
    delay(wait);
  for (int i = strip.numPixels(); i > 0; i--) {
    colorFast(0, 0);
    strip.show();
    delay(wait);
// scanner to midpoint
void bounceInOut(uint8_t num, uint8_t start, uint8_t wait) {
  colorFast(0, 0);
  uint8_t color = 200;
  for (int q = 0; q < num; q++) {
    if (strip.numPixels() - start >= 0 && start < NUM_LEDS) {
      strip.setPixelColor(start + q, strip.Color(0, color, 0));
      strip.setPixelColor(strip.numPixels() - start - q, strip.Color(0, color, 0));
    color = round(color / 2.0);
    strip.show();
    delay(wait);
  if (counter > strip.numPixels()) {
    counter = 0;
void fadeEveOdd(int c1, byte rem, uint8_t wait) {
  for (int j = 0; j < CTR_THRESH; j++) {
      if (i % 2 == rem) {
        HSVtoRGB(c1, 255, (255 / CTR_THRESH)*j, colors);
        strip.setPixelColor(i, colors[0], colors[1], colors[2]);
    strip.show();
    delay(wait);
  for (int j = CTR_THRESH; j >= 0; j--) {
      if (i % 2 == rem) {
    strip.show();
    delay(wait);
// twinkle random number of pixels
void twinkleRand(int num, uint32_t c, uint32_t bg, int wait) {
  // set background
  colorFast(bg, 0);
  // for each num
  for (int i = 0; i < num; i++) {
    strip.setPixelColor(random(strip.numPixels()), c);
  strip.show();
  delay(wait);
// sine wave, low (0-359),high (0-359), rate of change, wait
void wavey(int low, int high, float rt, uint8_t wait) {
  float in, out;
  int diff = high - low;
  int step = diff / strip.numPixels();
  for (in = 0; in < 6.283; in = in + rt) {
      out = sin(in + i * (6.283 / strip.numPixels())) * diff + low;
      HSVtoRGB(out, 255, 255, colors);
    strip.show();
    delay(wait);
#define NUM_LEDS 2
#define DATA_PIN 4
#define BTN_PIN 0
// Init Vars
uint8_t j = 0;
uint8_t myPix = 0;
uint8_t colors[3];
unsigned long mark;
// Start Strip
  EEPROM.begin();
  strip.begin();
  pattern = EPROM.read(0);
    pattern = 1;
  // choose a pattern
  EEPROM.update(0, pattern);
  // set direction
    j++;
    j--;
  if (j > 254) {
    direction = 0;
  if (j < 1) {
    direction = 1;
  switch (var) {
    case 1:
    case 2:
    case 3:
    case 4:
      colorFirefly(60);
      counter++;
    case 5:
      // rainbow solid
      rainbow(10);
      counter++;
    case 6:
      counter++;
    case 7:
    case 8:
      // solid color
    case 9:
      // fade even or odd
    case 10:
      // show rainbow
      rainbowCycle(10);
    j = 0;
    mark = millis();
    pattern++;
    return true;
  else {
    return false;
      strip.show();
      delay(wait);
      lastPix = myPix;
      counter = 0;
      colorFast(0, 0);
    strip.show();
    delay(wait);
    strip.show();
    delay(wait);
// fast version
  strip.show();
  delay(wait);
  uint16_t i;
  strip.show();
  delay(wait);
  uint16_t i;
  strip.show();
  delay(wait);
// scanner
    colorFast(0, 0);
    strip.show();
    delay(wait);
    colorFast(0, 0);
    strip.show();
    delay(wait);
  colorFast(0, 0);
    strip.show();
    delay(wait);
    counter = 0;
      if (i % 2 == rem) {
    strip.show();
    delay(wait);
      if (i % 2 == rem) {
    strip.show();
    delay(wait);
  // set background
  colorFast(bg, 0);
  // for each num
  strip.show();
  delay(wait);
  float in, out;
    strip.show();
    delay(wait);
simplified it a bit but doesnt work , did i do something wrong?
#include <FastLED.h>
#include <EEPROM.h>
#define NUM_LEDS 2
CRGB leds[NUM_LEDS];
#define DATA_PIN 4
#define CLOCK_PIN 13
#define MAX_BRIGHTNESS 160 // Thats full on, watch the power!
#define MIN_BRIGHTNESS 40 // set to a minimum of 25%
int val = 1;
int sequence = 1;
  //EEPROM.begin();
  FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
  //sequence = EEPROM.read(0);
  val = digitalRead(0);
  if (val == HIGH)
    if (sequence == 3)
      sequence = 1;
      sequence++;
      //EEPROM.update(0, sequence);
    delay(200);
  switch (sequence)
    case 1:
      FastLED.setBrightness(MIN_BRIGHTNESS);
      Strobe(0xff, 0xff, 0x00, 10, 20, 500); //byte red, byte green, byte blue, StrobeCount, FlashDelay, EndPause
    case 2:
      FastLED.setBrightness(MAX_BRIGHTNESS);
      TwinkleRandom(20, 100, false);
    case 3:
      FadeInOut(0xff, 0x77, 0xff);
void TwinkleRandom(int Count, int SpeedDelay, boolean OnlyOne) {
  setAll(0, 0, 0);
  for (int i = 0; i < Count; i++) {
    setPixel(random(NUM_LEDS), random(0, 255), random(0, 255), random(0, 255));
    showStrip();
    delay(SpeedDelay);
    if (OnlyOne) {
      setAll(0, 0, 0);
  delay(SpeedDelay);
void Strobe(byte red, byte green, byte blue, int StrobeCount, int FlashDelay, int EndPause) {
  for (int j = 0; j < StrobeCount; j++)
    setAll(red, green, blue);
    showStrip();
    delay(FlashDelay);
    setAll(0, 0, 0);
    showStrip();
    delay(FlashDelay);
  delay(EndPause);
void showStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H  // NeoPixel
  strip.show();
#endif
#ifndef ADAFRUIT_NEOPIXEL_H
  // FastLED
  FastLED.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
  // NeoPixel
  strip.setPixelColor(Pixel, strip.Color(red, green, blue));
#endif
  // FastLED
  leds[Pixel].r = red;
  leds[Pixel].g = green;
  leds[Pixel].b = blue;
#endif
void setAll(byte red, byte green, byte blue) {
  for (int i = 0; i < NUM_LEDS; i++ ) {
    setPixel(i, red, green, blue);
  showStrip();
void FadeInOut(byte red, byte green, byte blue)
  float r, g, b;
  for (int k = 0; k < 256; k = k + 1) {
    r = (k / 256.0) * red;
    g = (k / 256.0) * green;
    b = (k / 256.0) * blue;
    setAll(r, g, b);
    showStrip();
  for (int k = 255; k >= 0; k = k - 2) {
    setAll(r, g, b);
    showStrip();
