ATtiny85 External Interrupt to get out of Sleep Mode
Hi all,
I’m super new to hardware so forgive me for my ignorance :confused:
I’m trying to make something similar to Durr http://skreksto.re/products/durr. It is using the ATtiny85 (http://www.hobbytronics.co.uk/datasheets/ATTINY85.pdf) and I’m using an Arduino Uno as an ISP. It requires a vibration motor to turn on and off every five minutes, I’m using a watchdog timer to interrupt which is working fine. I also would like to turn the device on and off so I’m using an external interrupt.
But when I turn the device off and put it into sleep mode, it will not turn back on using the interrupt.
I have tried using an attachInterrupt and I didn’t get any better results. I think my main issue is understanding the sleep library.
I’ve taken the code from various places it is a bit of a hack job. Any help is appreciated! Thanks c:
// ATMEL ATTINY 25/45/85 / ARDUINO
// Ain0 (D 5) PB5  1|    |8  Vcc
// Ain3 (D 3) PB3  2|    |7  PB2 (D 2) Ain1   #SWITCH
// Ain2 (D 4) PB4  3|    |6  PB1 (D 1) pwm1
//            GND  4|    |5  PB0 (D 0) pwm0   #LED
#include <avr/sleep.h>
#include <avr/power.h>
#include <avr/wdt.h>
int countr; // WDT count
volatile unsigned int interruptedCount = 0; // INT0 count
const byte LED = 0;  // pin 5
const byte SWITCH = 2; // pin 7 / PCINT2
ISR(WDT_vect) {
  countr++;
ISR(PCINT0_vect) {
  if (interruptedCount >= 2) {
    digitalWrite(LED, LOW);
    sleep_mode();
    // sleepsies
    delay(10);
    if (digitalRead(SWITCH) == HIGH) {
        interruptedCount++; // debounce
void setup(){
  pinMode(LED, OUTPUT);
  pinMode(SWITCH, INPUT);
  setup_watchdog(6);
  set_sleep_mode (SLEEP_MODE_IDLE);
  sleep_enable();
  if (countr > 1){ // set to 1 second for testing purposes || 299
    countr = 0;
    digitalWrite(0, HIGH);
    digitalWrite(0, LOW);
void setup_watchdog(int timerPrescaler) {
  if (timerPrescaler > 9 ) timerPrescaler = 9; //Limit incoming amount to legal settings
  byte bb = timerPrescaler & 7;
  if (timerPrescaler > 7) bb |= (1<<5); //Set the special 5th bit if necessary
  //This order of commands is important and cannot be combined
  MCUSR &= ~(1<<WDRF); //Clear the watch dog reset
  WDTCR |= (1<<WDCE) | (1<<WDE); //Set WD_change enable, set WD enable
  WDTCR = bb; //Set new watchdog timeout value
  WDTCR |= _BV(WDIE); //Set the interrupt enable, this will keep unit from resetting after each int
  PCMSK  = bit (PCINT2); // want pin D4 / pin 3
  GIFR  |= bit (PCIF); // clear any outstanding interrupts
  GIMSK |= bit (PCIE); // enable pin change interrupts
I don't think an Attiny can be woken with an external interrupt. See section 9.2 of the datasheet compared to the equivalent section in the Atmega328 datasheet.
...R
Robin2: I don't think an Attiny can be woken with an external interrupt.
It does not matter. @hicough is using pin change interrupts which will wake the processor.
hicough: But when I turn the device off and put it into sleep mode, it will not turn back on using the interrupt.
You have misdiagnosed the problem. With Idle mode, the processor will wake the next time the millis timer overflows (approximately every 1ms). In other words, there will be a very short pause at the end of setup while the processor takes a nap and then loop will run.
