ATtiny85.... going slightly insane
Hello
I have an ATtiny85. Factory new, so I burnt the bootloader on at 8mhz.
Trying to run a short strip of ws2812 LEDS using Fastled and it just won't work. Its a timing issue.
I loaded Blink and it flashed madly fast, so I burnt the bootloader again a 1 Mhz and it seems correct now.
But, the code (it's a simple Fastled demo routine) won't load due to incorrect timings.
Can anyone advise what frequency to burn and then what to select to get the timing correct?
Thanks
Is your sketch in asm or c?
as expected. use some decimated lib, suitable for attinys.
