Attiny85 ir dimmer
i need little help here i'm traying to making dimmer circuit with attiny85 base on ir
but i have problem with may be code because it's work fine for relay but not working for dimming ac appliances
#include <EEPROM.h>
#define relay 1
const int irPin = 4;
int  load;
int spd;
#include <TimerOne.h>
volatile int i=0;               // Variable to use as a counter
volatile boolean zero_cross=0;  // Boolean to store a "switch" to tell us if we have crossed zero
int AC_pin = 3;                 // Output to Opto Triac
int dim2 = 0;                   // led control
int dim = 128;                  // Dimming level (0-128)  0 = on, 128 = 0ff
int freqStep = 75;    // This is the delay-per-brightness step in microseconds.
  //Serial.begin(9600);
  pinMode(AC_pin, OUTPUT);                          // Set the Triac pin as output
  pinMode(relay, OUTPUT);
  pinMode(irPin, INPUT);
  attachInterrupt(0, zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
  Timer1.initialize(freqStep);                      // Initialize TimerOne library for the freq we need
  Timer1.attachInterrupt(dim_check, freqStep);
  digitalWrite(relay, LOW);
  load = EEPROM.read(1);
  dim = EEPROM.read(2);
void zero_cross_detect()
  zero_cross = true;               // set the boolean to true to tell our dimming function that a zero cross has occured
  i=0;
  digitalWrite(AC_pin, LOW);
// Turn on the TRIAC at the appropriate time
void dim_check()
  if(zero_cross == true) {
    if(i>=dim) {
      digitalWrite(AC_pin, HIGH);  // turn on light
      i=0;  // reset time step counter
      zero_cross=false;    // reset zero cross detection
    else {
      i++;  // increment time step counter
int key = getIrKey();
  switch(key)
  case 1778:
    if (dim<127)
    dim = dim + 8;
    EEPROM.write(2, dim);
    if (dim>127)
      dim=128; // in vechiul sketch era 127
  case 1523:
  if (dim>5)
     dim = dim - 8;
  if (dim<0)
      dim=0;  // in vechiul sketch era 1
      case 2798:
          if (key == 2798 && digitalRead(1) == 1)
          { // For Load1 On
            load = 0;
            EEPROM.write(1, load);
            digitalWrite(relay, load);
          else if (key == 2798 && digitalRead(1) == 0)
          { // For Load1 Off
            load = 1;
int getIrKey()
  int len = pulseIn(irPin,LOW);
  int key, temp;
  key = 0;
  //Serial.print("len=");
  //Serial.println(len);
  if(len > 5000) {
    for(int i=1;i<=32;i++){
      temp = pulseIn(irPin,HIGH);
      if(temp > 1000)
        key = key + (1<<(i-17));
  if(key < 0 )
    key = -key;
  //if(key)
    //Serial.println(key);
    delay(250);
  return key;
please help me to find where do i mistake in code circuit just fine works with my nano with different
Hi .
in this routine:
case 2798:
       { // For Load1 On
         load = 0;
       { // For Load1 Off
         load = 1;
test key == 2798 && digitalRead(1) == 1
pin 1 (relay) is set to 0
load = 0;
then
test key == 2798 && digitalRead(1) == 0
and since pin 1 is 0
the relay is set to 1
load = 1;
The relay is one picosecond, it becomes 0, and then it becomes 1.
RV mineirin
Relay is just work fine it's perfectly turning on and of without any issues just my my led is not dimming it's just stay at highest brightness
