Hello, I have very simple circuit with Attiny85 powered by a CR2032 battery.
The Attiny85 is interrupted by a switch (47k pull-down) and turns on 2 LEDs for awhile and goes to deep sleep again.
This works very well with 3.3V from Arduino board, however when using CR2032, after about 20 times turning on, the Attiny85 does not go to sleep again (the LEDs turn on forever)
I don't know why and how to solve this problem.
Here is the code:
//Sleep Library to interrupt MCU
#include <avr/sleep.h>
#define INTERRUPT PCINT2 //Interrupt pin
//Define for Interrupt
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
void setup(){
pinMode(INTERRUPT,INPUT); //Setup interrupt pin
pinMode(4,OUTPUT); //LED pin
sbi(GIMSK,PCIE); // Turn on Pin Change interrupt
sbi(PCMSK,INTERRUPT); // Which pins are affected by the interrupt
void loop(){
digitalWrite(4,HIGH);delay(300);
digitalWrite(4,LOW);delay(300);
system_sleep(); //MCU Sleep
void system_sleep() {
cbi(ADCSRA,ADEN); // Switch Analog to Digital converter OFF
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Set sleep mode
sleep_mode(); // System sleeps here
sbi(ADCSRA,ADEN); // Switch Analog to Digital converter ON
I guess it is because the battery gets weak and can not support attiny85 to sleep ? or something wrong with the code ?
Thanks
