i bought a few attiny85 development boards(digispark compartible), i followed the instructions as per the video below. Cores load well, driver install correctly, code compiles as shown below, ISSUE is that the CODE DOES NOT UPLOAD
Video tutorial
Sketch uses 3100 bytes (51%) of program storage space. Maximum is 6012 bytes.
Global variables use 135 bytes of dynamic memory.{runtime.tools.micronucleus.path}/launcher -cdigispark --timeout 60 -Uflash:w:C:\Users~1\AppData\Local\Temp\arduino_build_47256/scrolling_text.ino.hex:i
java.io.IOException: Cannot run program “{runtime.tools.micronucleus.path}/launcher”: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:207)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.SketchController.upload(SketchController.java:713)
at processing.app.SketchController.exportApplet(SketchController.java:686)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2168)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
… 8 more
An error occurred while uploading the sketch
from experience i don’t think the code is the problem since i tried the “blink sketch” too, in vain. Even the timeout to plug in the board does not happen
Kindly assist if you may](TUTORIAL: Quickly Getting Started ATTINY85 - In 9 Minutes! (Digistump Serial Output) - YouTube)
