Attiny85 on 20mhz crystal?
Hello, I'm looking to upgrade the clock Clock Freq to 20mhz which capacitor should I use on 5v? Can someone please help me? I never used a external capacitor or crystal on a attiny85 before.
Joseph
Which capacitors are you referring to? You mention 5V, so do you mean the decoupling capacitor between GND and 5V? That stays the same.
You mention clock frequency. Perhaps you mean the capacitors that are associated with the crystal. The crystal datasheet should specify the values to use.
what ATTiny85 you have? Circuit diagram please to explain what you are changing
Hello all, I'm using a standard attiny85 from what I found online in ebay. I'm also using a 0.96 oled screen and a ds18b20 temperature sensor. I'm just trying to push it as high as I can go by using a External 20Mhz crystal. I found out I would need 2 18pf decoupling capacitor to make it work. The more I looked into it the more it was telling me I don't need the external crystal. I can Just run fine on the internal oscillator itself. I was originally Going add a 20mhz crystal bring the clock freq up as high as it can go. But now I don't think it is needed. I'm just making a temperature sensor I can carry around with a rechargable battery that is all.
Joseph
no such thing they may look the same but there are different models, which one is yours?
I typed that in wrong. My fat fingers on a small cellphone with a small screen. My fault there. The attiny85 I have is a Wing 8 pin smd. Not sure what you call it. Here is a link here.
Joseph
