ATTiny85; order of magnitude loss of speed when enabling map AnalogRead function
Hello Jiggy-Ninja
Well, spent a few more hours with this:
Now have two separate square waves / triangle wave, these square waves box BOTH the rising and falling edges...... :o See attached scope shot.
[code]
  if((micros()-StartUs) >= ramplength)
        Pwm+=Dir;                 //increment or decrement PWM depending of sign of Dir
        analogWrite(ledPin, Pwm); //Update built-in LED
        if(Pwm==pwmMax) Dir=-1;   //if PWM reaches the maximum: change direction
        if(Pwm==pwmMax)
          digitalWrite(outPin,LOW);
          delay(ramplength);
        if(Pwm==pwmMin)
          delay(INTERVAL);
          Dir=+1;                 //delay *INTERVAL* & change direction
          delayStartTime = micros();
              do
                INTERVAL   = map(analogRead(intervalPin),0,1023,800,50000);               //800=16ms          // adjust all maps according to
                pwmMax     = map(analogRead(pwmMaxPin),0,1023,100,255);                    // circuit layout & potentiomenters
                ramplength = map(analogRead(ramplengthPin),0,1023,2,11800);               // adjust map for packetcount
              while(micros()-delayStartTime<=INTERVAL);
          //StartUs += ramplength;  //loose control of ramplengthPin & pwmMaxPin // only intervalPin works // with int Dir=2; min 4ms
                                  //loose control of ramplengthPin  -- pwmMaxPin && intervalPin works  // with int static Dir=1;
            StartUs=micros();         //loose control of pwmMaxPin // ramplenghtPin & intervalPin works      // with int Dir=2; min 4ms
  }                                 // All three work!!!! but....now Triangle wave!!!!!                   // with int static Dir=1;
[/code]
Guess this is progress, but not how I envisaged it.
Now the pot. input for variable ramplengthPin only controls the pwmMax plateau of the triangle wave, making it no longer a triangle but a flat top triangle wave.
This wave form may be useful in future experiments, but not what is needed now.
I know that I am making some basic mistake with the format of this program.
I feel that I am close to making this work, I would definitely appreciate any pointer in the proper direction to expedite the process.
Thanks again.
take care, peace
lost_bro
