Hello, I want to make a code for attiny85 with 6 buttons where button one is connected to PIN 1, button 2 is connected to PIN 2, buttons 3 and 4 are connected to PIN 3, buttons 5 and 6 are connected to PIN 4. Create a program so that you don't get confused when you make a mistake. one of buttons 3 and 4 or buttons 5 and 6 is pressed without confusion. When one of the buttons is pressed it will send a hex code to the remote where pin 0 is used for the IR LED to send the hex code. Where buttons 3 and 4 each have a 1k resistor connected in parallel, similarly buttons 5 and 6 each have a 1k resistor connected in parallel, button 1 has a 1k resistor and button 2 has a 1k resistor.
#include <IRremote.h>
#define IR_PIN 0 // PB0 on ATtiny85 is pin 0 on Arduino IDE
IRsend irsend;
#define BUTTON1_PIN 1 // PB1 on ATtiny85 is pin 1 on Arduino IDE
#define BUTTON2_PIN 2 // PB2 on ATtiny85 is pin 2 on Arduino IDE
#define BUTTON3_PIN 3 // PB3 on ATtiny85 is pin 3 on Arduino IDE
#define BUTTON4_PIN 3 // PB3 on ATtiny85 is pin 3 on Arduino IDE
#define BUTTON5_PIN 4 // PB4 on ATtiny85 is pin 4 on Arduino IDE
#define BUTTON6_PIN 4 // PB4 on ATtiny85 is pin 4 on Arduino IDE
bool button3Pressed = false;
bool button5Pressed = false;
// Inisialisasi pin sebagai input tanpa pull-up internal
pinMode(BUTTON1_PIN, INPUT_PULLUP);
pinMode(BUTTON2_PIN, INPUT_PULLUP);
pinMode(BUTTON3_PIN, INPUT_PULLUP);
pinMode(BUTTON4_PIN, INPUT_PULLUP);
pinMode(BUTTON5_PIN, INPUT_PULLUP);
pinMode(BUTTON6_PIN, INPUT_PULLUP);
// Inisialisasi IR
irsend.begin(IR_PIN);
if (digitalRead(BUTTON1_PIN) == LOW) {
irsend.sendNEC(0xFFA25D, 32); // Ganti dengan kode yang sesuai untuk tombol 1
delay(300); // Debouncing delay
} else if (digitalRead(BUTTON2_PIN) == LOW) {
irsend.sendNEC(0xFF629D, 22); // Ganti dengan kode yang sesuai untuk tombol 2
} else if (digitalRead(BUTTON3_PIN) == LOW && !button3Pressed) {
button3Pressed = true; // Menandai tombol 3 telah ditekan
irsend.sendNEC(0xFFE21D, 32); // Ganti dengan kode yang sesuai untuk tombol 3
} else if (digitalRead(BUTTON3_PIN) == HIGH && button3Pressed) {
button3Pressed = false; // Menandai tombol 3 telah dilepas
} else if (digitalRead(BUTTON4_PIN) == LOW) {
irsend.sendNEC(0xFF22DD, 32); // Ganti dengan kode yang sesuai untuk tombol 4
} else if (digitalRead(BUTTON5_PIN) == LOW && !button5Pressed) {
button5Pressed = true; // Menandai tombol 5 telah ditekan
irsend.sendNEC(0xFF02FD, 32); // Ganti dengan kode yang sesuai untuk tombol 5
} else if (digitalRead(BUTTON5_PIN) == HIGH && button5Pressed) {
button5Pressed = false; // Menandai tombol 5 telah dilepas
} else if (digitalRead(BUTTON6_PIN) == LOW) {
irsend.sendNEC(0xFFC23D, 32); // Ganti dengan kode yang sesuai untuk tombol 6
or if you really really need to do it with those 4 pins, you could set 4 buttons to trigger one pin each, and two buttons that trigger two pins when pressed.
like:
button1 pin1
button2 pin2
button3 pin3
button4 pin4
button 5 pin1and2
button6 pin3and4
