ATtiny85 pullup resistor issue
Hi everyone, So I have been looking all over the internet and can not find a single site that helps me to disable the pullup resistor that's apparently ON by default on pin 7 of my ATtiny. I have no issue with any of my other pins but the output for pin 7 on my chip is slow it barely drives a LED on its own, I want to find out how to disable it but all I find online is how to enable them.
Does anyone out there know how I can disable the pullup resistor on pin 7 of an ATtiny85 chip?
I am using Arduino UNO to program this chip and my program is running fine aside from this one output which is way too low.
Thanks for all your help guys,
Steve
Pull-ups have no meaning for outputs.
Show us your code, a diagram and a picture of what you are doing.
Paul__B:
Perhaps the OP forgot to set it as an output wit pinMode....
JimboZA:
Ah yes, "barely drives a LED on its own" - that is the classic for the LED being fed by the pullup when set as an input!
I had figured out what I did wrong, I had called pin 2 an output, than for my input pins I had declared 2 an input instead of pin 3. I corrected the issue and all is working fine. Thanks for your replies.
