ATtiny85 + Shift Register = Trouble?
I've actually just ran into another problem unfortunately, no errors or anything but things are not working as they should. I'm using the ATtiny85 to run 9 different led animations using a couple of shift registers, and it works just fine if I run it off the arduino straight to the shift registers, but when I run it through the ATtiny (even within the capacity) the only three that will work are the same ones that worked before fixing all these PCREL issues. So I'm essentially back to square one... God damn it
Post your sketch.
