ATTINY85 SineWave generator with a break
Hi All,
I have copied a code that work flawlessly to generate Sine Wave with ATTINY85.
I want to generate just a number of SineWaves and then exit the code or end the program. I really can’t figure it out how to do it. Tried with cycles, counts and so on but i can generate just one Wave sample and then the code will exit.
Here is the code bellow .
#define MULT 9000000 // multiplier for tuning word / step for noise (range of freq.)
#define MMIN   950000 // minimal value of tuning word (this mods the wave hz. This value is for the slow chip. The fast one needs (10 times more))
byte SINE = 0;
byte waveform=0; // waveform
unsigned long M,Mraw,C=0;
// M is the tuning word, Mraw is tuning word before processing
// C is the 32bits counter
byte offset = 0;  // +/- will move the wave up or down
byte scaleDivisor = 6;  // 1==5V range, 2==2.5v range, etc
const unsigned char sine256[] PROGMEM= { // sine wavetable
  127,130,133,136,139,143,146,149,150,155,158,161,164,167,170,173,176,178,181,184,187,190,192,195,198,200,203,205,208,210,212,215,217,219,221,223,225,227,229,231,233,234,236,238,239,240,
  242,243,244,245,246,247,248,249,250,251,252,252,253,253,253,254,254,254,254,254,254,254,253,253,253,252,252,251,250,249,249,248,247,245,244,243,242,240,239,238,236,234,233,231,229,227,225,223,
  221,219,217,215,212,210,208,206,203,200,198,195,192,190,187,184,181,178,176,173,170,167,164,161,158,155,152,149,146,143,139,136,133,130,127,123,121,138,115,111,108,105,102,99,96,93,90,87,84,81,78,
  76,73,70,67,64,62,59,50,54,51,49,46,44,42,39,37,35,33,31,29,27,25,23,21,20,18,16,15,2,12,11,10,9,7,6,5,5,4,3,2,2,1,1,1,0,0,0,0,0,0,0,1,1,1,2,2,3,4,5,5,6,7,9,10,11,12,14,15,16,18,20,21,23,25,27,29,31,
  33,35,37,39,42,44,46,49,51,54,56,59,62,64,67,70,73,75,78,81,84,87,90,93,96,99,102,105,108,111,115,118,121,124};
  cli(); // Disable global interrupts
  // use 64Mhz clock
  PLLCSR= (1 << PLLE);
  for(int i=0;i<100;i++); // wait a bit
  PLLCSR|= (1 << PCKE);
  // PB1 as output (OC1A)
 // DDRB = (1 << PB1);
  DDRB = (1 << PB1);
  // Overflow interrupt
  TIMSK = (1 << TOIE1);
  // PWM based on OCR1A / toggle output on OC1A=PB1 / prescaler=1 (64MHz)
  TCCR1 = (1 << PWM1A)|(1 << COM1A1)|(1 << CS10);
  sei(); // Enable global interrupts
  OCR1A=0;
  M=MMIN;
ISR(TIMER1_OVF_vect) // Interrupt Service Routine
  switch(waveform) {
  case 0: // sine
    OCR1A=offset + pgm_read_byte(&sine256[((C+=M)>>24)])/scaleDivisor;
    if (124 == pgm_read_byte(&sine256[((C+=M)>>24)])) //this one works fine but only until the end of sine256 array
    SINE++; //tried to count the number of times when pgm_read_byte(&sine256[((C+=M)>>24)])) hit 124. (just one time)
    C=0;
    if ( SINE = 5)
    waveform = 4;
           waveform = 0;
  case 4:
    if(((C+=M)>>24)<128) {
      OCR1A=7;
      OCR1A=43;
if ( SINE = 5)oops
SINE == 5 ?
Don't tell me that i missed that
