ATTiny85 - sleep using Registers...
Been trying this as a learning exercise about regsiters and actually understanding datasheets much more in general...I know I could just copy code from the net and use libraries, but I want to understand what is actually going on "under the bonnet".
#include <avr/sleep.h>
#include <avr/io.h>        // Adds useful constants
#define red 0
#define yellow 1
#define button A2
#define temp_sensor A3
#define redOn digitalWrite(red,HIGH);
#define redOff digitalWrite(red,LOW);
#define yellowOn digitalWrite(yellow,HIGH);
#define yellowOff digitalWrite(yellow,LOW);
  pinMode(red, OUTPUT);
  pinMode(yellow, OUTPUT);
  pinMode(temp_sensor, INPUT);
  pinMode(button, INPUT_PULLUP);
  if (!digitalRead(button)) {
    decimalFlash(getTemp());
  gotoSleep();
float getTemp() {
  float millivolts = analogRead(temp_sensor) * (getVcc() / 1000.0);
  float voltage = millivolts / 1024.0;
  return (voltage - 0.5) * 100;
long getVcc() {
  //reads internal 1V1 reference against VCC
  ADMUX = _BV(MUX3) | _BV(MUX2); // For ATtiny85/45
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Convert
  while (bit_is_set(ADCSRA, ADSC));
  uint8_t low = ADCL;
  unsigned int val = (ADCH << 8) | low;
  //discard previous result
  low = ADCL;
  return ((long)1024 * 1100) / val;
void decimalFlash(int a) {
  unsigned int tens = a / 10;
  unsigned int units = a % 10;
  for (byte t = 0; t < tens; t++) {
    redOn
    delay(200);
    redOff
    delay(200);
  for (byte u = 0; u < units; u++) {
    yellowOn
    delay(200);
    yellowOff
    delay(200);
void gotoSleep() {
  SREG &= B01111111; // Disable I bit (interrupts).
  MCUCR |= (1 << SM1) | (0 << SM0); // Power Down Mode
  ADCSRA &= ~(1 << ADEN); //Disable ADC, saves ~230uA
  PRR = 0xFF;     // Power save.
  GIMSK |= (1 << PCIE); // General Interupts (Pin Change Interrupt)
  PCMSK = 0;
  PCMSK = (1 << PCINT4); // Any logic change on PB4 (PCINT4 / D4 / A2) causes interrupt.
  GIFR |= (1 << PCIF); // Flag set when interrupt occurs
  SREG |= B10000000; // Enable Interrupts...
  MCUCR |= (1 << SE); // Enable the sleep bit...
  sleep_cpu();
  sleep_disable();
  MCUCR |= (0 << SE); // Turn the sleep enable bit off.
  PRR = 0;        // Turn back on Modules.
  ADCSRA &= ~(0 << ADEN); //Enable ADC
I can't seem to wake the unit up again once it enters sleep.
Got a button from PB4 to GND.
The code I have written (tried to follow the datasheet) is at the very bottom.
