[ATtiny85] SoftwareSerial + Pin Change Interrupt
i want to build a Programmable CDI Ignition System for my Scooter with a Attiny85 µC.
the timing for Ignition is stored in the EEprom and should be changeable through a Serial connection (Arduino nano <-> attiny).
the ignition is triggered through a Pin Change Interrupt ISR on pin RB0, but if i include the Software Serial lib. i cant compile the sketch:
libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function `SoftwareSerial::read()':
(.text+0x0): multiple definition of `__vector_2'
sketch\CDI.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Fehler beim Kompilieren für das Board ATtiny25/45/85.
here is the sketch:
#include "avr/interrupt.h"
#include <EEPROM.h>
#include <SoftwareSerial.h>
//PICKUP = PB0
#define IGCOIL 1
#define RXPIN 2
#define TXPIN 3
unsigned int igdelay[150]; //[1] = 100rpm, [2] = 200rpm ...
volatile unsigned long revtime;
volatile int rpm;
volatile byte igindex;
SoftwareSerial softSerial(RXPIN, TXPIN);
  if(digitalRead(RXPIN)) serialconsole(); //the ignition should only be programable if RXPIN is High on startup
  else{
    readEE();
    GIMSK |= 0b00100000;    //turns on pin change interrupts
    PCMSK |= 0b00000001;    //turn on interrupt on PB0
    sei();                  //enable interrupts
    pinMode(IGCOIL, OUTPUT);
void loop(){} //Do nothing...
ISR(PCINT0_vect){
  if(digitalRead(0)){ //only run when RB0 = High
    rpm = 1000000 / (micros() - revtime) * 60;
    revtime = micros();
    igindex = rpm / 1000;
    delayMicroseconds(igdelay[igindex]);
    digitalWrite(IGCOIL, HIGH);
    delay(1);
    digitalWrite(IGCOIL, LOW);
void readEE(){
  for(int i = 0; i < 148; i++){
    igdelay[i] = EEPROM.read(i);
void writeEE(){
    EEPROM.update(i, igdelay[i]);
void serialconsole(){
  softSerial.begin(9600);
  softSerial.print("1");
  while(1){
    //not finished yet...
or is there another communication method between two arduinos (eg. i2c, SPI..)
Yes. Any of them can work. Keep in mind that the Attiny85 is NOT an Arduino.
