ATTINY85 timer 0 and pin 1
I have 2 questions.
I have some code that other people are using and it works for them, however when I try it the attiny85 does nothing. It should be sending pulses out on pin1 but I get nothing. I'm using arduino 1.6.7. could the version have anything to do with it.
Here is the code
#define BIT_SET(a,b) ((a) |= (1<<(b)))
#define BIT_CLEAR(a,b) ((a) &= ~(1<<(b)))
#define BIT_FLIP(a,b) ((a) ^= (1<<(b)))
#define BIT_CHECK(a,b) ((a) & (1<<(b)))
// CHANGE HERE THE ID OF TRANSPONDER
// possible values are 1 to 63
#define TRANSPONDER_ID 4
#define NUM_BITS  9
#define ZERO 250
#define ONE  650
unsigned int buffer[NUM_BITS];
unsigned int num_one_pulses = 0;
unsigned int get_pulse_width_for_buffer(int bit){
  if(BIT_CHECK(TRANSPONDER_ID,bit)){
    num_one_pulses += 1;
    return ONE;
  return ZERO;
unsigned int control_bit(){
  if(num_one_pulses % 2 >= 1){
    return ONE;
  }else{
    return ZERO;
  PORTB = 0;
  DDRB =  0b00000010;    // set PB1 (= OCR1A) to be an output
  setFrequency(38000); // 38 kHz
  buffer[0] = ZERO;
  buffer[1] = ZERO;
  buffer[2] = get_pulse_width_for_buffer(5);
  buffer[3] = get_pulse_width_for_buffer(4);
  buffer[4] = get_pulse_width_for_buffer(3);
  buffer[5] = get_pulse_width_for_buffer(2);
  buffer[6] = get_pulse_width_for_buffer(1);
  buffer[7] = get_pulse_width_for_buffer(0);
  buffer[8] = control_bit();
// Set the frequency that we will get on pin OCR1A but don't turn it on
void setFrequency(uint16_t freq)
 uint32_t requiredDivisor = (F_CPU/2)/(uint32_t)freq;
 uint16_t prescalerVal = 1;
 uint8_t prescalerBits = 1;
 while ((requiredDivisor + prescalerVal/2)/prescalerVal > 256)
   ++prescalerBits;
   prescalerVal <<= 1;
 uint8_t top = ((requiredDivisor + (prescalerVal/2))/prescalerVal) - 1;
 TCCR1 = (1 << CTC1) | prescalerBits;
 GTCCR = 0;
 OCR1C = top;
 TIMSK |=(1<<OCIE1A);
 TCCR1 |= (1 << COM1A0);
// Turn the frequency on
void ir_pulse_on()
 TCNT1 = 0;
// Turn the frequency off and turn off the IR LED.
// We let the counter continue running, we just turn off the OCR1A pin.
void ir_pulse_off()
 TCCR1 &= ~(1 << COM1A0);
void loop(){
  for(int i = 0; i < 3; i++){
    for(int b = 0; b < NUM_BITS; b++){
      switch(b){
        case 0:
          ir_pulse_on();
          delayMicroseconds(buffer[b]);
        case 1:
          ir_pulse_off();
        case 2:
          ir_pulse_on();
        case 3:
          ir_pulse_off();
        case 4:
          ir_pulse_on();
        case 5:
          ir_pulse_off();
        case 6:
          ir_pulse_on();
        case 7:
          ir_pulse_off();
        case 8:
          ir_pulse_on();
      ir_pulse_off();
    } // going through the buffer
    delay(20 + random(0, 5));
  } // 3 times
} // end of main loop
I changed the code to use timer0 instead of timer1 and it appears to work but it outputs on pin0 instead of pin 1. Can timer0 use pin 1? If so what do I change in the code below?
Thanks in advance.
#define TRANSPONDER_ID 1
#define NUM_BITS  9
#define ZERO 250
#define ONE  650
    return ONE;
  return ZERO;
    return ONE;
  }else{
    return ZERO;
  PORTB = 0;
  DDRB =  0b00000011;    // set PB1 (= OCR1A) to be an output
//DDRB |= (1<<PB0); //Set pin PB0 as output
  buffer[0] = ZERO;
  buffer[1] = ZERO;
 TCNT0 = 0;// set timer value to 0
 TCCR0A=0;
 TCCR0B=0;//Timer/Counter0 Control Register
 TCCR0A |=(1<<COM0A0); //Timer0 in toggle mode Table 11-2
 TCCR0A |=(1<<WGM01); //Start timer 1 in CTC mode Table 11.5
 TCCR0B |= (1 << CS00);// Prescaler table 11.6
 OCR0A=105; //CTC Compare value
void ir_pulse_on()
  TCNT0 = 0;
 // TCCR0B |= (1 << CS00);
void ir_pulse_off()
 //TCCR0B &= ~(1 << CS00);
 TCCR0A &= ~(1<<COM0A0);
void loop(){
      switch(b){
        case 0:
          ir_pulse_on();
        case 1:
          ir_pulse_off();
        case 2:
          ir_pulse_on();
        case 3:
          ir_pulse_off();
        case 4:
          ir_pulse_on();
        case 5:
          ir_pulse_off();
        case 6:
          ir_pulse_on();
        case 7:
          ir_pulse_off();
        case 8:
          ir_pulse_on();
      ir_pulse_off();
  } // 3 times
I'm using 1.0.6 for all my tiny85 efforts. 1.6.7 I'm using for ESP8266 and 1.7.8 for STM32F103.
I would strongly recommend going off-site and doing a google for tiny85 and timers. The information on tiny85 is scattered. I've done a couple of projects you are welcome to cannibalize.
Ray
