Attiny85 to drive an airwick
Hi!
I've always been annoyed that the airwick works all night, so I'd like to sort of watch with a ATtiny to operate only from 15 to 23 for example, and my questions are:
  • I can do with millis () (accepting that there will be a gap that will accumulate and each time have to reset X) or is essential an RTC?
  • The airwick powered by two AA batteries, so I guess I can feed directly ATtiny with that, then I plan scheme is to feed the airwick with a PWM output, is this possible? or I have to put a relay or transistor?
Thank you.
uveral:
    RTC
    Voltage drop during activation could cause t85 to reset, so a large capacitor may be required and t85 brown out fuses set appropriately
you will need a FET driver to handle the current for the AirWick
