ATTiny85 universal remote sending random signals
I've been following instructions on how to make a universal remote from an ATTiny85 microcontroller using this video: https://www.youtube.com/watch?v=_nm4if-lusI&list=WL&index=4
From there I used the IRremote library (4.1.0 version) to work with this code shown here:
#include <IRremote.h>
const byte butonPin = 2; //button input
const byte IRPin = 1; // LED output
   // connect button to ground and input
   pinMode(butonPin, INPUT_PULLUP);
   IrSender.begin(IRPin);
   static bool lastButtonState = HIGH;
   bool buttonState = digitalRead(butonPin);
   if (buttonState != lastButtonState)
      if (digitalRead(butonPin) == HIGH) {
      IrSender.sendNEC(0xEB14FD02, 32);
      lastButtonState = buttonState;
I asked the ATTiny to send this signal (0xEB14FD02) using the remote circuit shown in the YouTube video and tried to see if my arduino could pick it up on the serial monitor using the ReceiveDump example included in the library.
Here is the response from the old remote that I copied the signal from:
+9000,-4300
  • 650,- 500 + 650,-1550 + 650,- 450 + 650,- 450
  • 650,- 500 + 650,- 450 + 650,- 450 + 650,- 450
  • 650,-1600 + 650,- 450 + 650,-1550 + 650,-1600
  • 650,-1550 + 700,-1550 + 650,-1550 + 650,-1550
  • 700,- 450 + 650,- 450 + 700,-1500 + 700,- 450
  • 650,-1550 + 700,- 400 + 700,- 400 + 700,- 450
  • 650,-1550 + 700,-1550 + 650,- 450 + 650,-1550
  • 700,- 400 + 750,-1500 + 700,-1500 + 750,-1500
  • 700
Sum: 67350
Result as internal 8bit ticks (50 us) array - compensated with MARK_EXCESS_MICROS=20
uint8_t rawTicks[67] = {180,86, 13,10, 13,31, 13,9, 13,9, 13,10, 13,9, 13,9, 13,9, 13,32, 13,9, 13,31, 13,32, 13,31, 14,31, 13,31, 13,31, 14,9, 13,9, 14,30, 14,9, 13,31, 14,8, 14,8, 14,9, 13,31, 14,31, 13,9, 13,31, 14,8, 15,30, 14,30, 15,30, 14}; // Protocol=NEC Address=0x2 Command=0x14 Raw-Data=0xEB14FD02 32 bits LSB first
Result as microseconds array - compensated with MARK_EXCESS_MICROS=20
uint16_t rawData[67] = {8980,4320, 630,520, 630,1570, 630,470, 630,470, 630,520, 630,470, 630,470, 630,470, 630,1620, 630,470, 630,1570, 630,1620, 630,1570, 680,1570, 630,1570, 630,1570, 680,470, 630,470, 680,1520, 680,470, 630,1570, 680,420, 680,420, 680,470, 630,1570, 680,1570, 630,470, 630,1570, 680,420, 730,1520, 680,1520, 730,1520, 680}; // Protocol=NEC Address=0x2 Command=0x14 Raw-Data=0xEB14FD02 32 bits LSB first
uint16_t address = 0x2;
uint16_t command = 0x14;
uint32_t rawData = 0xEB14FD02;
Pronto Hex as string
char prontoData[] = "0000 006D 0022 0000 015B 00A5 001A 0012 001A 003B 001A 0011 001A 0011 001A 0012 001A 0011 001A 0011 001A 0011 001A 003D 001A 0011 001A 003B 001A 003D 001A 003B 001C 003B 001A 003B 001A 003B 001C 0011 001A 0011 001C 0039 001C 0011 001A 003B 001C 000F 001C 000F 001C 0011 001A 003B 001C 003B 001A 0011 001A 003B 001C 000F 001E 0039 001C 0039 001E 0039 001C 06C3 ";
Ln 1, Col 1
Arduino Uno
on COM5
And here are two examples of the responses I got from my ATTiny85 remote:
EX.#1
  • 150,- 150 + 200,- 100 + 150,- 100 + 200,- 150
  • 400,- 300 + 400,- 100 + 200,- 100 + 150,- 150
  • 150,- 150 + 150,- 100 + 200,- 100 + 200,- 150
  • 100,- 100 + 200,- 150 + 150,- 100 + 200,- 100
  • 200,- 100 + 150,- 150 + 150,- 100 + 200,- 100
  • 200,- 100 + 150,- 200 + 400,- 100 + 200,- 100
  • 200,- 100 + 150,- 150 + 200,- 100 + 150,- 100
  • 200,- 100 + 200,- 100 + 150,- 150 + 150,- 150
  • 450,- 100 + 150,- 150 + 200,- 100 + 150,- 100
  • 200,- 150 + 400,- 200 + 400,- 100 + 200
Sum: 13800
uint8_t rawTicks[337] = {8,2, 3,3, 4,2, 3,2, 4,3, 8,6, 8,2, 4,2, 3,3, 3,3, 3,2, 4,2, 4,3, 2,2, 4,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,4, 8,2, 4,2, 4,2, 3,3, 4,2, 3,2, 4,2, 4,2, 3,3, 3,3, 9,2, 3,3, 4,2, 3,2, 4,3, 8,4, 8,2, 4,2, 4,2, 3,3, 4,2, 3,3, 9,2, 3,3, 3,3, 3,3, 9,2, 3,3, 4,2, 3,2, 4,35, 7,2, 5,2, 3,2, 4,2, 3,3, 3,3, 3,2, 4,2, 4,3, 8,2, 4,2, 4,2, 4,2, 4,2, 3,2, 4,3, 3,2, 4,2, 3,4, 2,4, 8,2, 4,3, 2,2, 4,2, 4,2, 4,2, 4,2, 3,2, 4,2, 4,2, 4,2, 3,3, 4,2, 3,2, 3,3, 4,2, 3,3, 3,4, 8,2, 4,2, 3,3, 3,3, 3,2, 4,2, 4,2, 3,12, 8,2, 3,3, 3,3, 3,2, 4,2, 4,2, 3,4, 8,4, 1,3, 4,2, 3,3, 3,3, 9,2, 4,3, 9,72, 8,2, 4,3, 9,2, 3,4, 3,2, 3,3, 9,2, 4,2, 3,2, 4,2, 4,3, 8,3, 3,3, 9,2, 4,2, 3,3, 3,2, 4,5, 8,4, 8,3, 3,3, 2,16, 2,2, 4,2, 3,3, 4,2, 3,3, 3,3, 3,2, 3,3, 4,2, 3,2, 4,3, 8,4, 9,2, 3,2, 4,2, 4,2, 3,3, 3,3, 9,2, 3,4, 8,2, 4,2, 4,3, 8,2, 4,3, 3,2, 4,3, 8,2, 4,9, 2,4, 2,4, 2}; // Protocol=PulseWidth Raw-Data=0x61 168 bits LSB first
uint16_t rawData[337] = {380,120, 130,170, 180,120, 130,120, 180,170, 380,320, 380,120, 180,120, 130,170, 130,170, 130,120, 180,120, 180,170, 80,120, 180,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,220, 380,120, 180,120, 180,120, 130,170, 180,120, 130,120, 180,120, 180,120, 130,170, 130,170, 430,120, 130,170, 180,120, 130,120, 180,170, 380,220, 380,120, 180,120, 180,120, 130,170, 180,120, 130,170, 430,120, 130,170, 130,170, 130,170, 430,120, 130,170, 180,120, 130,120, 180,1770, 330,120, 230,120, 130,120, 180,120, 130,170, 130,170, 130,120, 180,120, 180,170, 380,120, 180,120, 180,120, 180,120, 180,120, 130,120, 180,170, 130,120, 180,120, 130,220, 80,220, 380,120, 180,170, 80,120, 180,120, 180,120, 180,120, 180,120, 130,120, 180,120, 180,120, 180,120, 130,170, 180,120, 130,120, 130,170, 180,120, 130,170, 130,220, 380,120, 180,120, 130,170, 130,170, 130,120, 180,120, 180,120, 130,620, 380,120, 130,170, 130,170, 130,120, 180,120, 180,120, 130,220, 380,220, 30,170, 180,120, 130,170, 130,170, 430,120, 180,170, 430,3620, 380,120, 180,170, 430,120, 130,220, 130,120, 130,170, 430,120, 180,120, 130,120, 180,120, 180,170, 380,170, 130,170, 430,120, 180,120, 130,170, 130,120, 180,270, 380,220, 380,170, 130,170, 80,820, 80,120, 180,120, 130,170, 180,120, 130,170, 130,170, 130,120, 130,170, 180,120, 130,120, 180,170, 380,220, 430,120, 130,120, 180,120, 180,120, 130,170, 130,170, 430,120, 130,220, 380,120, 180,120, 180,170, 380,120, 180,170, 130,120, 180,170, 380,120, 180,470, 80,220, 80,220, 80}; // Protocol=PulseWidth Raw-Data=0x61 168 bits LSB first
uint16_t address = 0x0;
uint16_t command = 0x0;
uint32_t rawData = 0x61;
char prontoData[] = "0000 006D 00A9 0000 0010 0003 0007 0005 0008 0003 0007 0003 0008 0005 0010 000B 0010 0003 0008 0003 0007 0005 0007 0005 0007 0003 0008 0003 0008 0005 0005 0003 0008 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0007 0010 0003 0008 0003 0008 0003 0007 0005 0008 0003 0007 0003 0008 0003 0008 0003 0007 0005 0007 0005 0012 0003 0007 0005 0008 0003 0007 0003 0008 0005 0010 0007 0010 0003 0008 0003 0008 0003 0007 0005 0008 0003 0007 0005 0012 0003 0007 0005 0007 0005 0007 0005 0012 0003 0007 0005 0008 0003 0007 0003 0008 0043 000E 0003 000A 0003 0007 0003 0008 0003 0007 0005 0007 0005 0007 0003 0008 0003 0008 0005 0010 0003 0008 0003 0008 0003 0008 0003 0008 0003 0007 0003 0008 0005 0007 0003 0008 0003 0007 0007 0005 0007 0010 0003 0008 0005 0005 0003 0008 0003 0008 0003 0008 0003 0008 0003 0007 0003 0008 0003 0008 0003 0008 0003 0007 0005 0008 0003 0007 0003 0007 0005 0008 0003 0007 0005 0007 0007 0010 0003 0008 0003 0007 0005 0007 0005 0007 0003 0008 0003 0008 0003 0007 0016 0010 0003 0007 0005 0007 0005 0007 0003 0008 0003 0008 0003 0007 0007 0010 0007 0003 0005 0008 0003 0007 0005 0007 0005 0012 0003 0008 0005 0012 008A 0010 0003 0008 0005 0012 0003 0007 0007 0007 0003 0007 0005 0012 0003 0008 0003 0007 0003 0008 0003 0008 0005 0010 0005 0007 0005 0012 0003 0008 0003 0007 0005 0007 0003 0008 0009 0010 0007 0010 0005 0007 0005 0005 001E 0005 0003 0008 0003 0007 0005 0008 0003 0007 0005 0007 0005 0007 0003 0007 0005 0008 0003 0007 0003 0008 0005 0010 0007 0012 0003 0007 0003 0008 0003 0008 0003 0007 0005 0007 0005 0012 0003 0007 0007 0010 0003 0008 0003 0008 0005 0010 0003 0008 0005 0007 0003 0008 0005 0010 0003 0008 0011 0005 0007 0005 0007 0005 06C3 ";
Ln 1, Col 1
Arduino Uno
on COM5
EX.#2
Raw result in internal ticks (50 us) - with leading gap
rawData[16]:
-277
  • 1,-22
  • 2,- 3 + 9,- 2 + 4,- 2 + 3,-10
  • 8,- 2 + 4,- 2 + 4
Sum: 78
Raw result in microseconds - with leading gap
rawData[16]:
-13850
  • 50,-1100
  • 100,- 150 + 450,- 100 + 200,- 100 + 150,- 500
  • 400,- 100 + 200,- 100 + 200
Sum: 3900
uint8_t rawTicks[15] = {1,22, 2,3, 9,2, 4,2, 3,10, 8,2, 4,2, 4}; // Protocol=UNKNOWN Hash=0x9DA6B59A 8 bits (incl. gap and start) received
uint16_t rawData[15] = {30,1120, 80,170, 430,120, 180,120, 130,520, 380,120, 180,120, 180}; // Protocol=UNKNOWN Hash=0x9DA6B59A 8 bits (incl. gap and start) received
char prontoData[] = "0000 006D 0008 0000 0003 002A 0005 0005 0012 0003 0008 0003 0007 0012 0010 0003 0008 0003 0008 06C3 ";
Ln 1, Col 1
Arduino Uno
on COM5
I am positive the circuit is setup properly but I am unsure if my coding was done correctly. If anyone has any guidance they can provide as to why my ATTiny is sending random signals rather than what it was programed to send, I would be most grateful.
Thank you for your time
I think you need to use an example for the newer version of the library. sendNEC() takes 3 arguments: address, command and repeats. Maybe try IrSender.sendNEC(0x2, 0x14, 0);.
Did this fix it?
It did not. Here is one of the 3 responses I got from it:
  • 200,- 100 + 200,- 100 + 150,- 150 + 150,- 100
  • 200,- 100 + 200
Sum: 24100
uint8_t rawTicks[421] = {8,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,4, 4,2, 3,3, 3,2, 4,2, 4,2, 4,2, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,4, 3,3, 3,3, 3,2, 4,2, 4,2, 4,2, 2,3, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 4,2, 3,2, 4,2, 4,2, 2,4, 4,1, 4,2, 3,3, 4,2, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,2, 4,2, 4,2, 3,3, 3,3, 3,2, 4,2, 2,5, 2,2, 4,2, 4,2, 4,2, 4,2, 2,59, 6,3, 4,2, 2,11, 8,2, 4,2, 4,2, 4,2, 3,2, 4,2, 2,5, 7,28, 7,16, 8,2, 4,2, 3,2, 4,2, 4,2, 4,2, 3,2, 4,2, 4,2, 3,3, 4,2, 3,2, 4,2, 3,3, 4,2, 3,2, 4,2, 3,3, 4,2, 3,2, 4,2, 3,3, 4,2, 3,2, 4,2, 3,3, 4,2, 3,5, 8,3, 3,3, 3,2, 4,2, 4,2, 3,2, 4,3, 9,2, 3,2, 4,3, 8,3, 3,2, 4,3, 2,3, 3,3, 3,4, 8,2, 3,4, 8,3, 2,3, 3,3, 4,2, 3,3, 9,3, 2,2, 4,3, 2,3, 4,2, 4,2, 3,2, 4,3, 2,3, 3,3, 3,2, 4,2, 4,2, 4}; // Protocol=UNKNOWN Hash=0x338C8C54 211 bits (incl. gap and start) received
uint16_t rawData[421] = {380,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,220, 180,120, 130,170, 130,120, 180,120, 180,120, 180,120, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,220, 130,170, 130,170, 130,120, 180,120, 180,120, 180,120, 80,170, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 180,120, 130,120, 180,120, 180,120, 80,220, 180,70, 180,120, 130,170, 180,120, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,120, 180,120, 180,120, 130,170, 130,170, 130,120, 180,120, 80,270, 80,120, 180,120, 180,120, 180,120, 180,120, 80,2970, 280,170, 180,120, 80,570, 380,120, 180,120, 180,120, 180,120, 130,120, 180,120, 80,270, 330,1420, 330,820, 380,120, 180,120, 130,120, 180,120, 180,120, 180,120, 130,120, 180,120, 180,120, 130,170, 180,120, 130,120, 180,120, 130,170, 180,120, 130,120, 180,120, 130,170, 180,120, 130,120, 180,120, 130,170, 180,120, 130,120, 180,120, 130,170, 180,120, 130,270, 380,170, 130,170, 130,120, 180,120, 180,120, 130,120, 180,170, 430,120, 130,120, 180,170, 380,170, 130,120, 180,170, 80,170, 130,170, 130,220, 380,120, 130,220, 380,170, 80,170, 130,170, 180,120, 130,170, 430,170, 80,120, 180,170, 80,170, 180,120, 180,120, 130,120, 180,170, 80,170, 130,170, 130,120, 180,120, 180,120, 180}; // Protocol=UNKNOWN Hash=0x338C8C54 211 bits (incl. gap and start) received
char prontoData[] = "0000 006D 00D3 0000 0010 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0007 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0008 0003 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0007 0007 0005 0007 0005 0007 0003 0008 0003 0008 0003 0008 0003 0005 0005 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0008 0003 0007 0003 0008 0003 0008 0003 0005 0007 0008 0001 0008 0003 0007 0005 0008 0003 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0003 0008 0003 0008 0003 0007 0005 0007 0005 0007 0003 0008 0003 0005 0009 0005 0003 0008 0003 0008 0003 0008 0003 0008 0003 0005 0071 000C 0005 0008 0003 0005 0014 0010 0003 0008 0003 0008 0003 0008 0003 0007 0003 0008 0003 0005 0009 000E 0035 000E 001E 0010 0003 0008 0003 0007 0003 0008 0003 0008 0003 0008 0003 0007 0003 0008 0003 0008 0003 0007 0005 0008 0003 0007 0003 0008 0003 0007 0005 0008 0003 0007 0003 0008 0003 0007 0005 0008 0003 0007 0003 0008 0003 0007 0005 0008 0003 0007 0003 0008 0003 0007 0005 0008 0003 0007 0009 0010 0005 0007 0005 0007 0003 0008 0003 0008 0003 0007 0003 0008 0005 0012 0003 0007 0003 0008 0005 0010 0005 0007 0003 0008 0005 0005 0005 0007 0005 0007 0007 0010 0003 0007 0007 0010 0005 0005 0005 0007 0005 0008 0003 0007 0005 0012 0005 0005 0003 0008 0005 0005 0005 0008 0003 0008 0003 0007 0003 0008 0005 0005 0005 0007 0005 0007 0003 0008 0003 0008 0003 0008 06C3 ";
Ln 1, Col 1
Arduino Uno
on COM5
3
The ATTiny is still just sending one random signal after another.
Can you please try to put a delay(200) into your loop-function? I've tried it with an Arduino UNO and a logic analyzer. Seems to be working fine. Your button isn't debounced so it could cause the send-function to run again. I'm not completely sure, if this could cause trouble but there is another thread where this was also suggested: IR send not sending consistent signal
Not exactly sure I did if i did it right but i added the delay as such:
{delay(200);
Still popping off random signals on the receiving end so it dosen't look like thar fixed it. I appreciate the help though so please let me know if you have any other ideas.
You did put the delay() into setup(). Try it like the following example:
    delay(200);
You can of course modify it to work when using the button. I just used it as test code.
Looks like wrong clock settings. Test with a 1 second blink.
