ATtiny85 with flex sensor
I tried this out on a nano:
int flexSensorPin = A7;//pin2 tiny
const int Piezo = 2; //pin0 tiny
void setup(){
  pinMode (Piezo, OUTPUT);
void loop(){
  int flexSensorReading = analogRead(flexSensorPin);
  if (flexSensorReading<250) {
    digitalWrite(Piezo, HIGH);
    digitalWrite(Piezo, LOW);
  delay(250);
Is it possible to run this off of a ATtiny85? I figured I can use pin 2 on the tiny for the sensor and pin 0 for the piezo. Ive uploaded the code to the tiny but nothing beeps as before. I changed the pin numbers. It worked fine on the nano.
Looks like you have the +V wire connected directly to the Ain pin ?
Yes, you mean the V+ from the 3.7V battery to the tiny's Vcc pin? I changed the image, I had a discrepancy from what I actually have. What I posted is larger, clearer and what I actually have.
I just found the problem.
It's called A1 not 2.
