I am looking for help to use the Nextion display with ATTiny85.
Pl help me out.
I am using arduino UNO as ISP and uploading a code in ATTiny85 programmed for 1 IR obstable sensor to display the in Nextion display.
Pl help me out.
Hello cvashish,
You were given help in your other post, which you have not responded to; Person counter using IR sensor and connected with nextion display - Programming Questions - Arduino Forum
If you don't respond when people try to help then the are unlikely to continue to help.
You have not said in this post what help you want.
Perry, I already responded with the feedback regarding my previous post but not sure what went wrong and it was not posted. Anyways Thanks man your method helped me alot.
Earlier i was trying to use nextion display along with arduino UNO board, i am using ATTiny85 and UNO as isp.
I have connected a IR sensor to PB1 and nextion RX TX to PB0 & PB2 resp.
After uploading the program, sensor is responding to the obstacles but data is not showing in Nextion.
To provide any useful help you will nee to provide:
Information about the IR sensor, what it actually is, maybe a link to where you bought it from, data-sheet.
A schematic of how you have connected everything, not a list of this connected to that.
Your Arduino code, please use code tags </>
Your Nextion configuration, you can put it into a zip file and upload that
Photos of what you have done also help.
And which tiny85 core are you using?
