ATTINY85V -> Arduino Serial
I am currently working on a sensor board for a project. I am thinking of having an ATTiny85V on the board, to read in 2 I2C values, and if I can work out how, a Dallas 1 wire temperature reading. I would then like to send this data via serial, to an Arduino or a computer. I was thinking that the data could be sent as one serial string, and decoded at the other end. I was wondering which pins on the Arduino/ATTiny I need to connect, and whether this would work. Also, is there any difference between sending serial data to an Arduino and, say, a Raspberry pi?
AntMan232:
You will probably need the I2C / TWI Master library for the ATtiny85; middle of the webpage...
http://code.google.com/p/arduino-tiny/
I believe it works unmodified on Tiny processors...
http://www.pjrc.com/teensy/td_libs_OneWire.html
Tiny Debug Serial...
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1285218245/25#25
Or you can use NewSoftSerial (I can't find the posts describing the necessary modifications but it does work).
No.
To use asynchronous serial communications will have to tune the processor...
Yes, a vast difference.
You can actually have an Arduino, but a Raspberry Pi...?
